» Online Users: 538
2 members and 536 guests
beatle, tonetone
Clutch Issues :(
Clutch Issues :( - October 23, 2011, 12:05 AM
Well, the bike is a track only bike and only has about 13K miles on it. It has been down a couple of times as well (all at the track) as most of you already know. Last accident was by far the worse but I put the bike together and everything seems to be in good shape. It rides just fine and shifts ok but when I was testing out the bike today I put it through the ringer a bit and the clutch is slipping like a mofo. I think that the slippage is occurring at such low mileage due to rough usage but I don't want to overlook the accident and other possible issues. Anyone have any ideas before I order another stock clutch?
Also, maybe unrelated but the bike seems to be overheating a bit quickly. Today it got up to 230 even with the fan running so I shut it off immediately. I'm going to flush the system again to see what's going on.
Thanks in advance!
Chris's Avatar
October 23, 2011, 12:19 AM
might be the lever or master cylinder sticking slightly. Did you replace the controls after the wreck?
"I didn't bring artillery. But I'm pleading with you, with tears in my eyes: If you fuck with me, I'll kill you all." -MG James Mattis, Iraq 2003
Ruining .net one post at a time
October 23, 2011, 12:31 AM
As for the clutch: Even if the controls check out ok I wouldn't order up a new clutch assembly until you take it apart and inspect it. Otherwise you're just spending money on parts you might not need.
October 23, 2011, 12:38 AM
Good call. I did replace the clutch lever since it was bent. I'm going to try to play with it and adjust it tomorrow.
Good call as well. I never took apart a clutch before though. I do have the k7 manual but from experience does anyone know how hard it is to take apart the clutch?
Chris's Avatar
October 23, 2011, 12:46 AM
taking a clutch apart is easy, just pay attention to the order of the plates.
October 23, 2011, 12:53 AM
Good deal. I'm going to try adjusting it tomorrow, then if that doesn't work. Taking the bish apart
BTW, I noticed that since the accident whenever I click it into gear while its on the rear stand it spins way too much even if the clutch lever is pulled in all the way. I know this is normal when the bike is cold but usually when it warms up a bit the spinning is almost none existent until you rev the motor.
October 23, 2011, 03:08 AM
Manual clutch lever should have 1/4 inch of play. It should not be tight just a little loose. kinda like your butthole. As for the over heating you might have an air bubble in the system some where. Manual should have a way to get it out.
