» Online Users: 524
0 members and 524 guests
clutch problem
got barrier?
dubplaya's Avatar
clutch problem - September 7, 2007, 12:36 AM
Ok so put the clutch back into my bike, push rod down the center, push thingy, bearing, pressure plate, everything is TQ'd to spec.
put the left side where the cable goes on....clutch won't engage (ie if its in gear and i pull in the lever it stays in gear)
any ideas?!
i've already tried to adjust the cable and does no good.
tomorrow going to drain the oil and see if anything internal is outta wack for some reason :/
DUCATI MONSTER
rubber ducky?!
coooooookie
Audicoupej's Avatar
September 7, 2007, 06:43 AM
This is annoying. Especially when you're working on a bike at 1AM!
Anyone?
John
'07 ZX-6R
NESBA #10
Sportbiketracktime #10
JEMM Auto detailing
Cars, Bikes, RV's, Trailers, bathtubs. If you pay me I will buff it.
Kat
Finally got a garage!
Kat's Avatar
September 7, 2007, 08:07 AM
I spent $75 at Coleman's to learn how to turn that little adjustment screw that hides under the case where the cable connects to the pin pulling parts (opposite the case that holds the clutch plates) although in my case the clutch was ALWAYS engaged giving me almost no power (I had a little power).
Have you turned this adjustment screw properly?
**Sara**
Kevers
September 7, 2007, 08:09 AM
I think you mean disengage.
Regardless, it could be a bunch of things. Best thing to do is start over and make sure you follow the manual precisely, oil the plates, install them in the right order, align markings (pressure plate and clutch boss may have punch marks), torque clutch spring bolts, make sure teeth on pull rod are aligned with gear on pull lever shaft, etc. etc. Procedure may vary by model, and I'm not sure what kind of bike you have.
got barrier?
dubplaya's Avatar
September 7, 2007, 08:10 AM
yes i have, i tinkered with that for ~20 min Kat....@ no given point on either the upper lever adjustment, or lower case adjustment did it work
I'll note that RDDY
everything was TQ'd to spec, plates and everything have oil.
DUCATI MONSTER
rubber ducky?!
coooooookie
Audicoupej's Avatar
September 7, 2007, 08:27 AM
How finicky is the clutch system? I mean, everything was done according to the repair manual, it's not like we just threw it in and hoped for the best.
John
'07 ZX-6R
NESBA #10
JEMM Auto detailing
September 7, 2007, 08:31 AM
Then maybe you have a parts issue. What was wrong with the clutch that it needed to be removed in the first place?
got barrier?
dubplaya's Avatar
September 7, 2007, 08:32 AM
clutch was fine it was my gear shift shaft that had to come out and be replaced
DUCATI MONSTER
rubber ducky?!
Kat
Kat's Avatar
September 7, 2007, 08:44 AM
And you screwed with the screw that adjusts the gear shift shaft BEFORE you fiddled with the cable adjustments? Just checking. I diddled the screw like the manual said, and it was still out of whack...
**Sara**
Kevers
got barrier?
dubplaya's Avatar
September 7, 2007, 08:53 AM
The screw that adjusts the shaft?
that shaft doesn't even have anything to do with the clutch...and its a fixed piece...
(i did find 1 small flaw on the install, we'll see later today
that bitch is coming all the way out and going to start again )
DUCATI MONSTER
rubber ducky?!
Kat
Kat's Avatar
September 7, 2007, 12:35 PM
I think that's the screw I'm talking about. It makes the rod longer and shorter, thereby adjusting the whole entire fit of the clutch! Get that screw wrong and you're well... screwed.
**Sara**
Kevers
