» Online Users: 537
3 members and 534 guests
Clutch and shift problems
TPG og
b00st's Avatar
Clutch and shift problems - June 28, 2012, 03:20 PM
Searched around but couldn't find exactly what I was looking for...
I have two problems with shifting. Sometimes when the bike is hot I can't get it to go into neutral at stoplights. Huge PITA to hold the clutch in at stoplights. Read to adjust the primary. Should I tighten the primary or loosen it to alleviate this? There is a bolt/adjuster IIRC on left side of bike. Actually it won't go itno any gear stopped, have to push it hard as hell. Primary oil has been changed to the synthetic v-twin stuff
Other prob is the clutch is only disengaging like 90% at a stop in 1st. It stop for the most part but can still feel it wanting to pull the bike a wee bit. Would this have anything to do with the CRGs being on the lowest setting for my midget hands? Or do I just need to adjust shift cable where it meets the lever?
Stop light racer...
pnbell's Avatar
June 28, 2012, 03:34 PM
Sounds like your clutch cable is stretched (not fully disengaging clutch) and needs to be adjusted. I am not familiar with your bike, but there is probably two adjustments: One at the Handlebar/Lever, and One at the Engine.
If so, adjust the engine one first, then the handlebar one.
- Sold, Red 81' GS650
- Sold, Black 81' CM400T
Stop light racer...
pnbell's Avatar
June 28, 2012, 03:37 PM
Looks like there is an inline cable adjuster.
see page 1-20 in this pdf:
http://www.badweatherbikers.com/buel...rvice/BU1b.pdf
TPG og
b00st's Avatar
June 28, 2012, 03:42 PM
Holy shit how'd you find that! I been googling badweb for a while. I have the service manual to, but nothing to figure out how to fix the specific problem. Thanks!!!
Pioli's Avatar
June 28, 2012, 03:45 PM
This is why this site is so great!
2008 Honda CBR1000rr
2004 Honda CBRF4i - Sold!
Stop light racer...
pnbell's Avatar
June 28, 2012, 03:54 PM
Let us know if that fixes it; i've worked on plenty of bikes, and this problem is common.
*Its Probably worse when warm because the RPMs are slightly higher, the cable is warmer and stretches a bit more, and the hot oil isn't allowing the clutch to slip as much as the cold oil..
June 28, 2012, 07:16 PM
Clutch plates are warped causing them to drag. If it's that buell use dynamite and record the explosion. Become famous on youtube.
LOL, kidding - Clutch cable adjustment if you've not ever adjusted it is the likely culprit (as mentioned above) - not only the cause of the dragging but also the hard shifting/finding neutral as well.
otb
otb's Avatar
June 28, 2012, 07:36 PM
+1...what he said...draggy clutch=impossible neutrals...
that is all....
Riding fast bikes slowly since 1969....
TPG og
b00st's Avatar
June 29, 2012, 08:38 AM
Thanks guys, I will adjust the clutch cable. Hopefully that knocks 2 birds out with one stone..or one adjustment! Ya'll think I need to adjust the primary to or unnessesary with clutch adjustment?
Stop light racer...
pnbell's Avatar
June 29, 2012, 09:43 AM
I would just start with the control cable adjustment.
↓ dn ʎɐʍ sıɥʇ ↓
Dark's Avatar
June 29, 2012, 11:04 AM
If it's an older/original clutch cable then I'd recommend buying a new one.
I had a clutch cable break on me 3 hours from one once, not cool.
TPG og
b00st's Avatar
June 29, 2012, 01:11 PM
Damn..so no shifting!!!
I will have to replace it. Barnett has some nice looking aftermarket ones to.
TPG og
b00st's Avatar
July 2, 2012, 02:01 PM
Disengaging problem fixed with clutch adjustment and primary fluid changed, thanks!
Now to test if getting into neutral at stop lights is still a problem...
July 2, 2012, 02:09 PM
1st do not buy an aftermarket cable for that bike. Get the OEM one.
2nd adjust at the primary cover 1st. You tighten the screw with a flat head screw driver till it bottom's out, this will be easy turns with almost no pressure, and then back it out 1/4 turn. Then adjust the cable at about half way up the cable. It will be infront of the motor. Then adjust if you have one at the bar. Also use 10/40 syn oil in primary. No need for the thick stuff.
