» Online Users: 566
1 members and 565 guests
Does a new air filter require rejetting the carb?
Derpetologist
Does a new air filter require rejetting the carb? - April 12, 2011, 10:33 PM
This question just occurred to me. I pulled out the nasty old OEM air filter and put in a fresh Moose racing one... is there a need to rejet?
Dude, playing the dude! K
clowe1243's Avatar
April 12, 2011, 11:46 PM
How bad are the carb jets now? Is it running rough? Over cleaning carbs will never hurt!
  Send a message via AIM to Send a message via AIM to clowe1243
GDMFSOB
The Evil Twin's Avatar
April 13, 2011, 07:14 AM
Just a filter? No.
Exhaust too? Maybe.
#132 EX
2015 MARRC Crash & Burn Award
Leoallafila's Avatar
April 13, 2011, 07:15 AM
You don't HAVE to, but assuming your new filter will let more air through, your air/fuel mixture will change, most likely becoming a little bit lean. Ride the bike and see if you can notice any power delivery problem, popping of the exhaust or excessive heat. Those are all indications of problems. Chaning the jetting/carburation on an engine is not easy, there are a LOT of factors.
2006 BMW R1200ST
2003 BMW K1200GT (Current)
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2005 Aprilia RSVR Factory
2001 Triumph Tiger 955i
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Suzuki GSX-1100R
1991 Honda Africa Twin 750
2004 Aprilia RSVR Factory
1990 Aprilia Pegaso 125
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
↓ dn ʎɐʍ sıɥʇ ↓
Dark's Avatar
April 13, 2011, 09:07 AM
A performance filter will usually yield less power on a carb'd bike without a re-jet (sometime a simple needle adjustment will fix it). Most tend to stick with the stock filters to save the hassle.
If the Moose Racing filter is relatively close to stock then you should be fine.
Derpetologist
April 13, 2011, 12:57 PM
Well there's a little bit of popping on decel, a little rpm "sticking", and I think the accelerator pump might need adjusting, it is hesitant when I whack the throttle open... not sure if it comes from the new air filter but I guess i should get to a shop.
↓ dn ʎɐʍ sıɥʇ ↓
Dark's Avatar
April 13, 2011, 01:04 PM
Yup.
April 13, 2011, 01:57 PM
Originally Posted by Dark View Post
Yup.
+1
2006 BMW R1200ST
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
April 13, 2011, 03:39 PM
If you're not sure what you're doing, then you would want to consider having a shop tune the carbs. If you just changed out the filter and find the bike running a little lean, a simple shimming (or lowering the e-clips) the needles can be suffice.
April 13, 2011, 09:12 PM
You need the air/fuel screw adjusted. It takes about 10 minutes and the bike will run way better. The stock air box is very restrictive so even the stock air filter is capable of flowing way more air than the small air box ports will allow to enter. The moose filters are awesome and will work well for you. If you need help just pm me.
↓ dn ʎɐʍ sıɥʇ ↓
Dark's Avatar
April 13, 2011, 09:55 PM
Aren't those adjustment screws normally for the pilot jets and not the mains?
On vacation
RileysDad's Avatar
April 13, 2011, 09:58 PM
Bump for a good dude. If anyone can help you out, it's this guy.
She asked my opinion
April 13, 2011, 10:11 PM
Yep, but a decel back fire with a hanging idle are all signs of a lean pilot circuit
and I'm betting it would clear up the throttle response issue as well.
April 13, 2011, 10:12 PM
Thanks man. Have you had a chance to do any reading in the new book?
On vacation
RileysDad's Avatar
April 13, 2011, 10:23 PM
Yep, I'm finishing up the first chapter. The book is awesome, I can't wait to start putting some of this stuff to use.
