» Online Users: 525
2 members and 523 guests
beatle, Leoallafila
electrical system?
I came I saw I shat mysef
jron's Avatar
electrical system? - September 20, 2009, 03:50 PM
Well, I finally tried to get my bike going again and stuck a new battery in it. But its now acting like the battery has no juice in it. Its a new battery and the battery tender goes green.. The bike was running just fine when I last rode it.. So I am annoyed. Did I just happen to get a bad replacement battery? It *was* sitting for a few months before I put it in the bike. But it was on a battery tender much of that time.
Any suggestions?
-john
wera, ccs - novice # 979 - sv650
Aprilia Falco (sold), Gs500 (sold), KTM300 (sold)
"I'll believe corporations are people when Texas executes one of them."
Separation of Corp. And State!
R.I.P Alex Lyskawa - My heart will never heal from your passing.
  MySpace.com Page Send a message via AIM to Send a message via AIM to jron
Get Tarded!
Tarded Jake's Avatar
September 20, 2009, 04:23 PM
If a battery sits for a period of time on concrete or metal it will easily ground out; which it may show a full charge but is actually creating a false peak. When put under load for a short period of time you can then take a multimeter and take a reading so try turning on the headlight on high for a few seconds then take a reading. Most chargers under $100 wont be able to detect a false peak if so you may need to take a analogue trickle charger induce a small charge and try the tender again.
If your getting a green like your saying the battery is most likely false peaking or completely toast. If the tender you bought if from had it sit for a while it may be grounded out and if so its probably toast.
I just bought a replacement a while back from www.batterymart.com
they are close and get good reviews I am very happy with them. I had the same thing happen you did with my charger.
September 20, 2009, 07:36 PM
Are you getting any lights when turning on the key? If not check the main fuse.
September 20, 2009, 07:39 PM
If you have a short somewhere draining the battery, you may have killed the new battery...
