» Online Users: 534
2 members and 532 guests
beatle, Nobrains
Fog light wiring harness with relay
Derpetologist
Fog light wiring harness with relay - March 31, 2013, 07:05 PM
I drew up wiring sketch for some fog lights I'm planning to install - am i doing it right?
I used this as a guide: Wiring a Relay for Accessories
Also what's your favorite relay switching source? I indicated the ignition wire in the sketch, but now I'm thinking of connecting to my license plate light wire which is already hacked from a fender eliminator job. Opinions?
I'm planning to install some fog lights I've had sitting around forever (ADV Monster in case you're wondering). They're 3 mode lights, 24W max. The power level is switched by flipping them on and off within a 2 second window IIRC. I'm thinking of building a harness for them, and eventually maybe adding on an outlet for things like heated gear, cig lighter outlet, coffeemaker, etc. to this. I'll be using 16 ga wire. I have no idea if an FZ8 alternator can handle all that, but that's what I'm thinking.
Gots_a_sol's Avatar
March 31, 2013, 07:08 PM
30 is your power source (from the battery)
87 goes to whatever you are turning on
-Joe
17 Beta 250RR/RE
09 Husky WR177
Derpetologist
March 31, 2013, 08:16 PM
Gotcha. The back of the package indicates otherwise but now I get it (interchangeable in this case only because there's no 87a pin). Thanks!
Derpetologist
April 8, 2013, 07:40 AM
Well I am just now realizing these exist. They look way better than my spare parts hackjob plan
Centech AP-2 Dual Fuse Panel : Amazon.com : Automotive Centech AP-2 Dual Fuse Panel : Amazon.com : Automotive
Centech AP-2 Dual Fuse Panel : Amazon.com : AutomotiveCentech AP-2 Dual Fuse Panel : Amazon.com : Automotive
Eastern Beaver PC-8
FUZEBLOCKS.COM
edit - nevermind, the fuse panels aren't too expensive, but the fuse panels + relay kits are more than I want to spend. I may still get something out of making my own relay.
↓ dn ʎɐʍ sıɥʇ ↓
Dark's Avatar
April 8, 2013, 09:07 AM
The kicker is going to be the module that adjusts the output. Is it built in to said relay (I hope not), the rocker switch, or a standalone unit?
Derpetologist
April 8, 2013, 09:20 AM
You mean the light output? That's built into the light units themselves. The 3-mode lights were discontinued awhile ago though and no longer appear on the adv monster site.
