» Online Users: 554
6 members and 548 guests
CCS762ZX6, davidcycle, Nobrains, Sal_the_man, Scot, Slider
Fork Seal Question
Air-Cooled Goodness
Desmo's Avatar
Fork Seal Question - October 13, 2016, 02:00 PM
Using the .net phone a friend feature. The fork seal on my Tiger 800XCX is blown. I called the dealer and replacement is not covered under warranty. I would like to replace it myself, but I've been searching the internet and haven't been able to locate any information about the fork. No replacement seals, no spring rates, no oil weight or level.
Any one have any ideas or suggestions? Should I just take it apart and measure the seal to identify a replacement?
-Tommy
October 13, 2016, 02:48 PM
Google says they're Showa 45mm upside down forks.
Hit bikebandit.com for part numbers.
October 13, 2016, 03:39 PM
Get the SKF green seal kit. Much better than OEM. Less stiction, long life.
SKF part# KITG-45S - You'll need two kits to do both sides.
Edit: Oops. I see you have an XCX, not an XC.
The XCX should has 43mm WP forks, not Showa.
My Chicken eats Busa's
October 13, 2016, 03:40 PM
You should probably take it to Brooks Cycles if you've never done it before. But, in the event you want to brave it on your own:
Part Number: 56-133AB (ALL BALLZ)
Fork Oil Left Grade SAE 5W
Fork Oil Right Grade SAE 5W
Fork Oil Left Capacity 664 ML
Fork Oil Right Capacity 664 ML
Fork Oil Purchase Quantity 1328 ML
Fork Oil KYB Left Level 117 MM
Fork Oil Right Level 117 MM
Triple Clamp Top Crown Nut Torque 90 NM
Front Axle Torque 65 NM
Front Axle Pinch Bolts Torque 22 NM
Front Brake Caliper Mount Bolts Torque 50 NM
2003 Honda SuperHawk
Click here for Brooks Cycles!
October 13, 2016, 03:47 PM
Looks like the SKF green seal kit part# for the 43mm WP forks is KITG-43W. But you'll want to verify that before ording if you decide to not go OEM.
October 13, 2016, 04:22 PM
I would go with the skf seals. They are the best period! We sell them at RNR cycles.
Triumph-ant
Sal_the_man's Avatar
October 13, 2016, 07:56 PM
Is it that difficult of a process? One of the seals on my daytona is going out apparently. But I think I'll swap the Racetech forks from the speed triple
1996 GS500E - Sold
2001 Speed Triple 955i - Sold
1999 Daytona 955i - Sold
2000 Ducati 748S
October 14, 2016, 10:51 PM
Racetech sells a nice book --> The Suspension Bible. It's about $30. It will help you through most basic suspension activities. Fork seals aren't too difficult if you are mechanically inclined. But it is typically a bit messy, and you might need a few tools you don't currently have.
I do my own suspension. Spent around $500 or so in tools to be able to do front and back for my bikes. Saved far more than that each year. Good investment.
Triumph-ant
October 14, 2016, 11:18 PM
Thanks for the tip. I'll look into the book
1996 GS500E - Sold
2000 Ducati 748S
shiphteey's Avatar
October 15, 2016, 01:06 PM
Kinda like doing chain and sprockets...specialized tools that the average end user doesn't feel like buying....but will pay for itself with repeated use.
Its a matter of whether its worth your time and initial investment into those tools. Time vs money.
www.GeminiMotorcycles.com
ZX14: 222 mph
ZX12: 229.6 mph
ZX10: 202.8 mph
ZX9: 177.6 mph
ZX6R: 180.8 mph
EX650: 130.7 mph
EX300: 114.7 mph
EX250: 122.4 mph
October 15, 2016, 03:07 PM
Correct. For fork seals, your tools investment is likely minimal. And in some cases would be effectively zero. The ones that come to mind are fork cap tools, large hex to remove damper bottom bolt, and sometimes a clip to hold the fork spring.
I did have to grind an open ended wrench to fit the internal nut for a set of forks. Again, minimal cost as I already had the wrench and grinder.
Having the right tool makes it simple.
Air-Cooled Goodness
Desmo's Avatar
October 17, 2016, 11:08 AM
Thanks for the answers everyone. I should've mentioned that the XCX has 43mm WP forks. I pulled the leaky one apart yesterday and it was cake. Standard USD open chamber fork from what I can tell. No installed preload so I didn't even need to use the spring compressor.
I ordered the SKF KITG-43W fork seals based upon the recommendations. Since I already have the forks apart I was planning on putting them back together with slightly stiffer springs and slightly heavier oil (10w), to support my fat ass. These being somewhat off-road forks with twice the travel of other forks I have worked on, I have no idea what spring rate to go with.. On a street bike of similar weight I would use 1kg/mm springs. I know I need to go way lighter than that, but I'm not sure how much lighter. I'm open to any suggestions about spring rate, oil weight, and level.
Windblown - what did you end up doing with your Tiger after it let you down?
-Tommy
October 17, 2016, 11:43 AM
Opted to do a motor swap after taking a close look at the motor and calculating parts costs. Found a good deal on a used motor out of a wrecked '14 800XC due to show up at my door today.
Triumph-ant
October 17, 2016, 02:06 PM
Right on. Did you order the motor from Ebay? I scored a GS500 motor for $240 but had to drive 8 hours roundtrip to pick it up from Ohio.
955i motors are pricy. In the $800 - $1000 range.
1996 GS500E - Sold
2000 Ducati 748S
shiphteey's Avatar
October 17, 2016, 02:19 PM
Ohio Mile bruH?
ZX14: 222 mph
ZX12: 229.6 mph
ZX10: 202.8 mph
ZX9: 177.6 mph
ZX6R: 180.8 mph
EX650: 130.7 mph
EX300: 114.7 mph
EX250: 122.4 mph
