» Online Users: 493
2 members and 491 guests
GRN96WS6, nootherids
found this attached to my oil plug
Riz
Hallmark card?!?
Riz's Avatar
found this attached to my oil plug - November 3, 2014, 08:52 AM
So was doing my oil change yesterday and found this. Any idea what this could be. Should i be concerned? Its smooth and hard. Bike is a 2012 gsxr 600 with 12k miles, mix of street and track riding. Always changed my oil after 4 trackdays or 2500 miles.
November 3, 2014, 08:57 AM
let me know when you go to part it out. thanks
CCS AM # 204
Range Rover Owner
iw84u's Avatar
November 3, 2014, 09:01 AM
did it drain out of the pan?
Riz
Hallmark card?!?
Riz's Avatar
November 3, 2014, 09:07 AM
Was attached to the magnetic plug
November 3, 2014, 09:10 AM
Looks like a valve retainer clip, yes I would be worried.
100% Kawasaki Biased
Thomas's Avatar
November 3, 2014, 09:11 AM
Valve keeper or valve guide, perhaps? Yeah, you need to start digging around that motor before something explodes (if the damage has not been done already).
You can live in your car, but you can't race your house.
'07 ZX-10R - 156 RWHP/182 MPH
'09 KX450F - VCHSS 29F
'85 ZL-900 Eliminator
'01 Ninja 250 (Sold)
'06 636 (Sold)
'99 ZX-6R (Sold)
'94 Ninja 250 (Sold)
'99 YZ-250 (Sold)
'73 CL 450 (Sold)
http://www.youtube.com/watch?v=a6Jpc...eature=related
http://videos.streetfire.net/video/H...bud_408656.htmfeature=related
The difference between men and boys is that boys make excuses and men make changes.
Riz
Hallmark card?!?
Riz's Avatar
November 3, 2014, 09:27 AM
Hmmm, is this not odd given how low the miles are and new the bike is? Is this something that may be covered under warranty ( i have no idea what the manufacuturers warranty is and cant remember if i bout extended warranty or not)
I had a minor lowside at the track, im wondering if that had anything tondo with it? Ive done beaver and a few wv rides since then, with no change in performance at all.
November 3, 2014, 09:38 AM
I had a minor lowside at njmp in july, im wondering if that had anything tondo with it? Ive done beaver and a few wv rides since then, with no change in performance at all.
manf warrantys are typically 1 year...if its a valve keeper and it made it from the head all the way to the bottom of the oil pan that whole motor prob should taken apart seeing that isnt the whole keeper so the rest of it in in there somewhere...sucks big time...
CCS AM # 204
Thomas's Avatar
November 3, 2014, 09:48 AM
You are incredibly lucky if only one keeper jumped from a valve. Pull the valve cover, do all the same steps that you would to adjust your valves, and take a look. I would not ride that bike again (or even start it) until I knew exactly what happened in that motor.
'06 636 (Sold)
'99 ZX-6R (Sold)
'99 YZ-250 (Sold)
'73 CL 450 (Sold)
Thomas's Avatar
November 3, 2014, 09:52 AM
FYI - I just googled for it and I'm 99% sure that's a valve keeper, which means one of your valves is being held up by only 1.... awesome luck that you found this before it went boom.
'06 636 (Sold)
'99 ZX-6R (Sold)
'99 YZ-250 (Sold)
'73 CL 450 (Sold)
LoneRider's Avatar
November 3, 2014, 10:01 AM
Definitely looks like a keeper, has the valves ever been out, valve job or any motor work?
I never seen one come out from factory but have seen them come out when valve train not assembled correctly, or professionally, keepers not seated, checked, etc.
Dont turn motor over at all, pull valve cover off and you should see 2 keepers per valve. Also, most likely the other keeper is floating around somewhere and the motor is ready to drop a valve, which would cause all kinds of damage.
Have it checked out before you even turn the motor over at all, dont try adjusting the valves, dont even turn it over manually.
November 3, 2014, 10:05 AM
It is a valve keeper. And yeah, it means you have one of two things happening:
1. A set was accidentally dropped into the motor and hasn't damaged anything inside you engine spinning through it at speed.
2. One of your valves has lost it's valve keeper and is about to drop and contact your piston. At speed.
In either case it's worth digging into the engine to be safe.
TTViper's Avatar
November 3, 2014, 10:06 AM
A similar thing happened to a previous bike of mine, fortunately nothing happened, but it came from the service techs at Colemans FC dropping it into my engine and not telling me about it. I found it shortly after when I changed the oil and found it like you did.
Definitley don't start it until you figue out where it is missing from.
2013 Hypermotard
1998 Superhawk
LoneRider's Avatar
November 3, 2014, 10:10 AM
Heres a typical keepers
Here is where you want to check each valve to see both keepers
November 3, 2014, 10:50 AM
i will buy the whole roller off you for a couple G's
CCS AM # 204
