» Online Users: 553
3 members and 550 guests
2blueyam, amit, GRN96WS6
Frame Swap?
Frame Swap? - September 29, 2009, 07:26 PM
How much would it cost to do a frame swap on an R1? I think my frame is slightly bent at the neck, it rides straight without using any hands, but something isn't right. Anyway if I bought a clean frame off ebay with a good title how hard or how much would it cost to swap out all the parts?
It was me.
Widow Maker's Avatar
September 29, 2009, 07:42 PM
Not hard. Just time consuming. Frames are cheap.
Mohawk Ryderz Road Captain
www.MohawkRyderz.com
"We drop sukaz!"
September 29, 2009, 07:48 PM
Well why would your frame be bent? If it is bent then your forks should be bent. Maybe even your triple tree.
Avatar adds 80lbs
ArlingtonRider's Avatar
September 29, 2009, 07:59 PM
Oh, its a total Pain in the ass. The set up is the key. You need to have two well stabilzed stations as you rip parts from one to the other.
I do not think it is a task for most mortals to attempt solo.
Call around to shops - i would expect estimates between 20-50 hours of labor.
September 29, 2009, 08:06 PM
Do-able in a day with the correct tools on hand.
It was me.
Also true.
"We drop sukaz!"
September 29, 2009, 08:08 PM
My fairings don't fit right, when I bought the bike they were secured with zip ties, if I try and use bolts with it the front wheel catches the fairings when I turn farthest left or farthest right. The header pipes are very close to the front wheel as well....looks to be closer than "normal" R1's.
Nick....can you point me in the right direction to find a frame?
Thanks guys
Avatar adds 80lbs
September 29, 2009, 08:15 PM
Hmmmm. AMA or serious racing crowd sure for track bike....i would say even a decent shop would take close to two days for street bike.
Ya gotta add at least 3-4 hours for the electronics wiring...total pain (imo).
September 29, 2009, 08:32 PM
20 -50 hours? WOW that would be 2 to 5 grand for a frame swap! Should be only about 10 hours. I have done many frame swaps at the track and street bikes.
September 29, 2009, 08:38 PM
I've essentially rebuilt my VFR several times now within a day. I'm pretty certain a VFR is more complex than an R1.
Avatar adds 80lbs
September 29, 2009, 08:39 PM
Yeah - i bet u get ranges from 20 hours up for a street bike.
Cost wise 1200-2500 is what i would expect, unless shops are all charging 100 per hour now?
I assume from 60-80 per hour.
You meet the nicest
WKDBLD's Avatar
September 29, 2009, 08:51 PM
Hmmmm.
harnesses can be a pain in the ass
Dodge knows this stuff, Rick at RnR can give a direct quote.
My '87 is built like a battleship
BECAUSE I GET OFF ON IT!
Avatar adds 80lbs
September 29, 2009, 09:35 PM
10 hours of labor?
That is what RNR charges for frame swaps of street bikes?
That is impressive. I assume full exhausts are flat rate of 1 hour too?
I hate Hybrid drivers
david636's Avatar
September 29, 2009, 09:46 PM
rides straight but feels funny? check your tires for proper air pressure and/or replace them.
September 29, 2009, 10:29 PM
10-12 hours max! We do frames all the time for insurance company's. It's not hard just takes some time.
