» Online Users: 446
0 members and 446 guests
HArd time cold starting
CrookedKing's Avatar
HArd time cold starting - September 4, 2011, 12:04 PM
Hello
My bike lately has had a hard time cold starting as shown in this video
It runs just fine after it does start up though, and I always start with the choke fully on (not sure why I didn't have it fully on in the video but the same problem occurs in any case)
I haven't checked the carbs yet but I want more opinions before I take them out as I have never cleaned carbs before and don't want to screw something up
-Ray
What is a chicken strip?
vtwinjunkie's Avatar
September 4, 2011, 12:35 PM
How often do you ride the bike? my first suggestion to you would be to check the condition/ charge of your battery....and how about the condition of the gas?
Sure a partially clogged pilot jet could cause a hard start but you would also be dealing with idle issues to 1/4 throttle....also these would not be affected by temperature, meaning it would not matter weather the bike was warm or cold.
Throw a charge on that battery and try again. I always hook the battery tender up when I am not going to be riding for more than a week.
September 4, 2011, 01:01 PM
I try to ride it every day when I can..and I put a fresh battery in and the problem was still there. I have had the bike for 1k miles and the 7-11 premium gas i've been using has worked so far up until 100 miles ago when this started
September 4, 2011, 02:35 PM
I've had 3 of these bikes & just fixed the same problem on mine. Does it also have trouble idling until you've ridden for a while & bike is very warm?
1. tight exhaust valve
2. need to re-adjust your float height.
3. intake boots cracked
I can help you out next weekend if you like
#1 Machine: Open Class Suzuki GS500K2 / Bridgestone package
#2 Machine: Factory Suzuki GSXR600K6 / Bridgestone package - Garage queen
September 4, 2011, 08:20 PM
Well I start it up on 100% choke so it hangs at like 4k while I put my gear on, then lower choke to around 50% so it hangs at like 2kish, then after a few minutes of riding I put choke completely off and it idles just fine.
and dude I would buy you a nice ass lunch if you can fix this problem for me lol. I'm gonna try running some seafoam through the gas tank and see if that helps anything
September 5, 2011, 06:41 AM
Yeah sounds like the beginning of a tight exhaust valve...then it will get worse until it doesn't want to idle. If you use the choke for 2 min or so and turn it off is it able to idle very slowly at least?
How many miles on it? Can't mess around with doing valve adjustments & checking oil on these bikes.
September 5, 2011, 09:15 AM
YEah after 2 minutes or so of choke if I turn it all the way off then it idles low like around 900rpms but I think that's because the engine simply has to warm up.
I bought it at 7k miles, i'm the 3rd owner, no idea what maintenance 1st or 2nd owner did (my fault for not inquiring past "yeah i took care of the bike")
It's now at 8400. I think it's the float thingy you mentioned because one morning when it was having the problems I saw that the petcock was on prime (no idea how it got there, i keep it on ON) but the problem continued
September 5, 2011, 10:11 AM
1st thing is to check the valves, definitely due for adjustment. You know it's the float if you use the choke & the engine doesn't spin up to 4k like yours is doing fine or you notice fuel coming out the airbox drain.
September 5, 2011, 10:28 AM
i took off my tank and i'm trying to put it back on but i can't get the damn fuel hoses in all the way! so i left them in partially (i spent an hour trying to get them to fit in) and I turned the main petcock under the tank to ON and now there's fuel dripping
this is the last time i work on my bike! i'm frustrated!!!
on topic, do you have the tools for valve adjustment? because i sure don't :X also where are you located?
September 5, 2011, 06:44 PM
no need to remove the tank unless you are going to remove carbs
PM sent.
September 9, 2011, 06:00 PM
huge thanks to BlkOnBlk600r for helping me fix it! it was a tight valve..
September 12, 2011, 07:32 AM
