» Online Users: 561
2 members and 559 guests
beatle, Leoallafila
Headlight Option...VERTICA FAIRING HEADLIGHT
Headlight Option...VERTICA FAIRING HEADLIGHT - April 1, 2009, 07:52 PM
Im a new owner of a 05 SV650S and have been researching the idea of new headlights for my naked conversion.
I am hoping that this forum can provide some info on the headlight shown above..I found it here
http://www.flyncycle.com/ProductDeta...Code=HLUVERBLK
At $49.99 for the set up(i think its for the whole setup)...it sure beats the cost of the buell setup.....
says it comes "complete with mounting rubbers"....don't know if thats all i'll need to fit on the SV650S.
Anyone with advice or experience on this?
April 1, 2009, 09:11 PM
pretty positive those aren't DOT approved (if that matters or not to you...it doesn't to me, i'm runnin some cheapo $20 fog lights for headlights now lol). The lights you mentioned don't shine that bright as they are only 20w bulbs (i think)....unless you do some kind of upgrade then you have to worry about melting the plastic (headlight housing) with a higher wattage bulb = more heat. Also, not being DOT approved means it's prolly some cheapo plastic which is why only a 20W bulb is used....trust me...there's more out there...keep searchin and g/l
if you haven't already...a check out http://www.acerbis.com/p001_frontpage/frontpage.html
i'm lookin for a headlight for my naked gsxr too
..besides...that's ugly as sin
TPG
pbrownw's Avatar
April 1, 2009, 09:55 PM
http://www.flyncycle.com/Replacement.../hluragblk.htm
that's what I have on my bike, it comes with what you need to mount it, those rubber straps go around the forks and attach to those plastic brackets which bolt to the headlight itself, the mounts on the light itself are slotted to allow for adjustability so it's aimed correctly. I also reinforced with some zipties to make it extra secure. Mine has 4 bulbs instead of 2 but it's pretty decent at night, not as good as stock but certainly fine, I'm not sure I'd go with the 2 bulb one though. I know the acerbis ones are better but I couldn't see dropping a couple hundred bucks on one unfortunately. Good luck and oh since they ship from China don't expect to see it for a couple weeks.
Tags
headlight, sv650, sv650s, vertica
