» Online Users: 549
3 members and 546 guests
How do I change da battery in my 01 cbr600 f41
Angry How do I change da battery in my 01 cbr600 f41 - May 19, 2008, 11:01 PM
I wanted to charge it but I dont know where to put the positive and negative connects it does not say on the back seat and I dont see any colors or signs so I want to try to replace the batter can some one HELP PLEASE
old fat and slow
bambam's Avatar
May 19, 2008, 11:27 PM
it should be under the front seat. the battery should be marked and the positive should have a red cover over the connection. if you are getting in there you might want to go ahead and install the wiring for a battery tender so the pig-tail can be routed so it is accessable w/o taking everything apart. the pig tail can be purchased for about $6 at most bike shops. the tender will run you about $35 and should include the tail as well.
here is a link to the service book should you have any questions.
http://www.repairmanualclub.com/index.php?dlid=163
i also have it on pdf file if that dosnt work just shoot me an e-mail addy that can recieve a large file.
MissS:no now!!!
MissS: I changed my mind
May 20, 2008, 12:01 AM
The battery itself will also have a raised + near the positive terminal and a - near the ground terminal. Be careful. Remove the ground cable first when removing the battery. Don't touch any metal on the bike while connecting or disconnecting the positive cable.
2001 honda 929
Hooks's Avatar
May 20, 2008, 08:23 AM
Make sure when u change your bat. To put the red rubber cap back over the terminal. Mine was lifted by the corner of the battery casing. I had a helmet lock in my trunk that slid down to the bat. When I was doing a standup (ON A PRIVATE RD.) The helmet lock slipped under the rubber cap and grounded the bike. Thus shutting it off and send a malfunction lite, while I was doing the wheelie. All was good just grabbed the clutch. Freak accident I know, but I now know the cap is there for a reason.
