» Online Users: 577
1 members and 576 guests
I guess I won't know if I don't ask!!!
Flores703's Avatar
I guess I won't know if I don't ask!!! - June 7, 2010, 07:23 AM
My 05 r6 chokes at high rpm!!!
In first gear it chokes at 10-11rpm then I have to change gear so it gets more power... And this keeps going I think till 4 gear but it's not at the same rpm all times... What could this be???
08- 99 cbr f4---sold
08-05 r6 --- sold
08-03 streetfighter cbr rr crash need parts
super pucket bike x19
11- 06 zx6r 636
GET SOME ! ! !
Spyker's Avatar
June 7, 2010, 07:25 AM
How old is the fuel? How old are the spark plugs, are all the cylinders firing properly?
Flores703's Avatar
June 7, 2010, 07:32 AM
I been riding the bike and I have put new fuel in there like 5 times... The plugs I got told they got change in dec of 08...and the cylinders I have know idea how do
I check that
08-05 r6 --- sold
11- 06 zx6r 636
Don't call my name
KO Photos's Avatar
June 7, 2010, 07:42 AM
Wow I effed up
Did you check your plugs and such after that incident?
Occasional rider, occasional photographer
KnockOut Photography
https://www.facebook.com/KnockOutMotoPhotos
Flores703's Avatar
June 7, 2010, 07:50 AM
Originally Posted by MissS View Post
Wow I effed up
Ahhhhh no I didn't
08-05 r6 --- sold
11- 06 zx6r 636
GET SOME ! ! !
Spyker's Avatar
June 7, 2010, 08:01 AM
I would start with the plugs, its a cheap way of knowing they aren't the cause of your problems, as far as the cylinders firing....if your bike is cold, start it up, and feel each exhaust header, right where it connects to the engine, and see if they are all equally warm (do it right when you fire it up, b/c it WILL get hot FAST), that's just a quick way of checking, by all means its not a 100% reliable way of checking (since they are all connected to one another through tubes that equalize the exhaust pressure).
Flores703's Avatar
June 7, 2010, 08:43 AM
Aight thanks I'll burn myself later on today
08-05 r6 --- sold
11- 06 zx6r 636
Flores703's Avatar
June 7, 2010, 08:50 AM
Isn't there a tool that checks pressure of the cylinders??? Where can I get one
08-05 r6 --- sold
11- 06 zx6r 636
June 7, 2010, 10:12 AM
As others said...start by changing the plugs (make sure all the connections are solid as well...I've had one pop off before) If that does not cure the issue, you may need a valve adjustment. The plugs and checking over everything is a good start though.
Flores703's Avatar
June 7, 2010, 10:21 AM
Sounds good
08-05 r6 --- sold
11- 06 zx6r 636
Flores703's Avatar
June 7, 2010, 01:14 PM
Wait let me rewrite this.....when I'm
riding and let's say I'm
trying to go faster I'm going and going and when it gets To 10-12rpm it's stuck like if there's something that's not letting gas get by... Like
then i feel that the "gas" gets by and then starts getting faster... I just got valve cover gasket change
08-05 r6 --- sold
11- 06 zx6r 636
Flores703's Avatar
June 8, 2010, 09:34 AM
Anyone???
08-05 r6 --- sold
11- 06 zx6r 636
#swag
Nick's Avatar
June 8, 2010, 09:36 AM
Did you follow the advice that people have given you on here? Or are you trying to figure a way to get around doing what people are suggesting?
Flores703's Avatar
June 8, 2010, 11:43 AM
Okokok this what I got and I need your help
08-05 r6 --- sold
11- 06 zx6r 636
Flores703's Avatar
June 8, 2010, 11:50 AM
Part number one this picture is call air cut valve ass'y as you guys can see it has three hose coming out of it and two going to the valve cover as show in the picture well my bike doesn't have the hose and the cap case that are on the valve cover arent the same as showing in this picture mine are just flat with no tube coming out them so could this be making my problem??
08-05 r6 --- sold
11- 06 zx6r 636
