» Online Users: 539
2 members and 537 guests
beatle, Nobrains
Just replaced spark plugs, now runs rough in high rpm
High Flyin!
portermg's Avatar
Just replaced spark plugs, now runs rough in high rpm - July 8, 2012, 08:32 PM
I bought My 2000 R6 about 4-5 months ago. It was running ok...with some high rpm on idle, but after riding for a month or so, the bike seemed to be running pretty darn good.
This weekend I changed the oil, the spark plugs and cleaned the stock air filter.
I started her up and she idles like a champ, no problems. However, when I took her for a ride last night, I noticed that she was having trouble under power. When I am in gear and going she sometimes felt like she was missing and I was not getting the power that I am used to. I used the same plugs that I took out (NGK CR10EK). Am I missing something? I am shocked on what could have happened in the whole tune up process. Nothing was wrong until I changed the plugs.
NOTE: I also checked the gaps for the proper gap size and they were all around 0.027 in. Which checks out ok in the service manual...
Any ideas fellas?
SRWJTS SGT-At-Arms
Fitz's Avatar
July 8, 2012, 08:46 PM
Wires?
-Fitz
2016 Harley Softail Slim S
2012 V-Strom 1000 Sold!
2009 Buell 1125R Sold!
2005 Superhawk Sold!
2001 Superhawk Abandoned!
1981 CB650C Destroyed!
Derpetologist
July 8, 2012, 09:03 PM
2000 r6 is carbureted right?
you mentioned having a funny idle before cleaning your air filter and an improvement after. I wonder if you uncovered something with your carburetor's tune in the process at presumably, high RPM / open throttle.
Leoallafila's Avatar
July 8, 2012, 10:18 PM
1) did you pinch a fuel line?
2) when replacing sparkplugs, did you seat them properly? As in tighten them, un-tighten them half a turn and then doing a final tightening? You could have a slight leak.
Other than that simply retrace what you did and look for f-ups.
2006 BMW R1200ST
2003 BMW K1200GT (Current)
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2005 Aprilia RSVR Factory
2001 Triumph Tiger 955i
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Suzuki GSX-1100R
1991 Honda Africa Twin 750
2004 Aprilia RSVR Factory
1990 Aprilia Pegaso 125
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
Member of SRWJTS
HumanNippy's Avatar
July 8, 2012, 11:08 PM
I'd wager that the fuel line got kinked slightly in the process. Or there is a vacuum leak somewhere along the way, a vacuum leak will cause high rpms and low rpms but it depend on the severity of the leak.
2001 Kawasaki ZX6R: Yoshi slip-on
1999 Trans AM WS6, Long tubes, full exhaust, extra sexy
2006 GTO 6spd, 1 of 390 Silver, SLP LM1 (Sold)
2001 R1; blue, Yoshi slip on (sold Jan 12, 2012)
(RIP) 2000 Camaro SS
1999 Trans Am Ws6 30k miles, 6spd (sold)
1999 Camaro coupe 6 cyl (traded in after a week to get the SS)
High Flyin!
portermg's Avatar
July 9, 2012, 07:54 AM
Wires?
Fitz, I dont think its the wires as everything was running good before the plug replacement.
Rail, the funny idle was not fixed by cleaning the air filter months ago...the idle was fixed more or less by the seafoam that I was adding to the fuel, and to the idle dial on the right side of the bike. I got it to where it was running very good.
Leo/Nippy, the possibility is there that I potentially pinched a fuel line, however the problem that I am having is intermitent and happens 50% of the time. The other 50% of the time the bike performs like it should. Thats the confusing part. Also, if I kinked the fuel line, wouldn't the bike idle funny? The bike is idling very good.
I think I will check on how the spark plugs are seated and get back to you all. Thank you for your help.
SRWJTS SGT-At-Arms
Fitz's Avatar
July 9, 2012, 07:59 AM
Should replace wires when replacing plugs. Possible also something got routed wrong and a wire got messed up (this happened to me, and produced the same symptoms you described)
-Fitz
↓ dn ʎɐʍ sıɥʇ ↓
Dark's Avatar
July 9, 2012, 08:02 AM
+1
replace wires regardless...
High Flyin!
portermg's Avatar
July 9, 2012, 08:09 AM
Ok, I'll give this a shot... Any recommendations on where to pick up new plug wires?
High Flyin!
portermg's Avatar
July 9, 2012, 08:28 AM
I hope this isnt a dumb question tho....but you guys do know that I do not have traditional spark plug wires, right? I have ignition coils. There are wires that plug into these of course, but I cannot find any replacements anywhere and I personally do not think they are meant to be replaced.
SRWJTS SGT-At-Arms
Fitz's Avatar
July 9, 2012, 08:33 AM
Yeah. I just googled and it appears you are right.
*shrug*
-Fitz
July 9, 2012, 08:35 AM
Make sure the coils are seated all the way in. You should feel a clicking as you push them on. I have seen a many times the owner change plugs and then the bike does not run right. Also when it is warmed up use windex and spray the headers. The spray should evap the same across all tubes. If it does not then maybe you have a dead coil. Or maybe a fuel problem.
The last urrbendah
Stillie's Avatar
July 9, 2012, 08:48 AM
What Mike said. Drop a good push on those coils. Sounds like they are a bit loose and that's causing contact issues at higher RPMs.
13 KTM 200 XC-W
15 KTM 350 XC-F
July 9, 2012, 09:28 AM
I agree to make sure the coils are pushed down all the way.
If you had to dump in sea foam, your carbs probably need some TLC. There could could be some debis in the main jet or they could be in dire need of syncing. Do you know if there is a jet kit installed?
I hate Hybrid drivers
david636's Avatar
July 9, 2012, 09:48 AM
My coils went bad. Read the thread below. It sounds like the same thing you have going on. I'm going to bet that your coils aren't pushed down all the way.
ZX6R acting funny - what's wrong with it?
