» Online Users: 543
4 members and 539 guests
2blueyam, davidcycle, GRN96WS6, onel0wcubn
Newb question: Patching a tire.
Pew pew.
datsit's Avatar
Newb question: Patching a tire. - August 29, 2011, 09:22 AM
Hey guys, hope this is the right section for this. I think technically it could fit into two other sections. In any case, I ride an 09 FZ6R and a few weekends ago, I ran into a nail. Didn't notice until the next morning when it had deflated a bit. My question is has anyone had any success using a patch kit similar to this?
Slime T-Handle Reamer Plugger Kit - Street Bike - Motorcycle Superstore
Pretty simple. You pull the nail out, shove the wick in, cut off the excess and seal it with cement. The nail is embedded in the tread. Anything I should be concerned about? Is it a bad idea? The nail a standard phillips head, maybe about half a fingernail in diameter for the head.
Thanks in advance!
--2009 yamaha fz6r on the street.
--2011 ducati 848 in my head.
Knarly Adventurer
wildjester's Avatar
August 29, 2011, 09:32 AM
Use the thread search feature... this has been dcovered about as much as what brand of oil to use.
Consensus says - Ok to plug for temp use / straight line commuting at or slightly above posted limit. Do not ride baller or rail the twisties till you get new tire.
2013 Triumph Tiger 800XC
2009 Scrambler SOLD
2007 ZX14 SOLD
2005 R1 SOLD
1999 ZRX SOLD
1996 FZR SOLD
GET SOME ! ! !
Spyker's Avatar
August 29, 2011, 09:33 AM
Its one of those subjects where some will give you their story how they plugged a tire, and it never gave them any problems and they wouldn't give you any flak for using a plug kit on a sportbike tire.
And then you're going to get people like me, that would tell you to buy a new rear. Just to be safe, plugging a rear tire might work for a day, might work for a month, might work for a year, but the idea of having a hole in the tire and putting a temporary fix on a vehicle where if you were to lose 1 tire, you lose 50% of your stability, traction, control, etc....not worth the risk in my book, but again, only my $0.02
GET SOME ! ! !
Spyker's Avatar
August 29, 2011, 09:34 AM
yeah, pretty much what wildjester said, I guess it can be summed up in a lot fewer words than I used
Give me the Ban Button!
Nubbs's Avatar
August 29, 2011, 09:36 AM
Thats a plug kit not a patch.
Those plugs are good for car tires. I personally would never run that type of plug in a bike tire for anything more than just trying to get the bike home on a very straight smooth road.
The safest thing you can do is replace the tire.
Some people will patch tires. This is when you take the tire off the rim and basically glue a patch of rubber over the hole from the inside.
They also have some some decent tire plug kits out there. Dodge plugged one of my tires once while we were on a ride with that type and it worked well to get me home safe.
Pew pew.
datsit's Avatar
August 29, 2011, 09:45 AM
Sorry, I did try a search, but maybe I was entering the wrong keywords. Thanks for the heads up.
I don't have an SUV to tow it or anything of the sort, so I'll try to figure it out. Thanks!
August 29, 2011, 10:51 AM
Can it be done? Yup. Will it work? Yes, if done properly and the damage is minimal and not in a critical/weak area of the tire.
You said nail, but described a screw. The process you mentioned was short on a couple of important steps. Actual damage to the tire cannot be inspected by remote. Therefore my gut instinct says to tell you to get the tire replaced. A MC tire is probably not the best choice for a "How to plug a tire" lesson.
