» Online Users: 534
2 members and 532 guests
beatle, Leoallafila
no oil pressure after change?
easyrider
1Bronco's Avatar
no oil pressure after change? - July 3, 2009, 05:21 PM
just got done changing the oil in my bike, 1996 zx6. i go to take it for a spin around the neighborhood to make sure nothing is leaking and i now get the red oil pressure light coming on. all i did was drain oil, take off old filter, and replace all. Anyone have any idea what would cause this?
Ninja in Training....
roadrunner78's Avatar
July 3, 2009, 05:22 PM
Did you put enough in?
- Craig
If you don't know go ask yo momma
'04 R1 aka "The Bastard"
  Send a message via AIM to Send a message via Yahoo to roadrunner78 Send a message via AIM to roadrunner78
easyrider
1Bronco's Avatar
July 3, 2009, 05:31 PM
oil is to the top line of the higher tick mark on the indicator window. that's where is should be correct?
This Ain't My First Time!
cf3232's Avatar
July 3, 2009, 05:36 PM
It should be to that line with the bike in the full upright position, not on the kickstand.
~Blutarski~
Dodge131:
easyrider
1Bronco's Avatar
July 3, 2009, 05:38 PM
right, its at that level with me holding the bike level off of the kickstand, when its on the kickstand it is lower then that
donniecs's Avatar
July 3, 2009, 05:41 PM
Fresh oil can look clear in the window, it's hard to judge sometimes. So it may be low (not up to the slight glass) or over serviced (filled beyond the site glass).
Charlie
Space's Avatar
July 3, 2009, 06:05 PM
Start it you should see the oil level in the site glass drop or disappear. If not you def. have a problem. Spin on Filter?
easyrider
1Bronco's Avatar
July 3, 2009, 06:06 PM
Ill check it when I get back home,I put 3.6L in it which is what it says on the bike,when I drained the oil it seemed like there was more then that though in it
easyrider
1Bronco's Avatar
July 3, 2009, 06:16 PM
double post
July 3, 2009, 07:11 PM
Wrong filter?
easyrider
1Bronco's Avatar
July 3, 2009, 07:31 PM
yes spin on filter
Originally Posted by windblown View Post
Wrong filter?
thats what im thinking because it was running like a champ prior to oil change. Im running a purolator pure one part number PL14612. looks the same size as the one that was on there before but could be wrong.
Space's Avatar
July 3, 2009, 07:38 PM
yes spin on filter
That should not be the problem. I run that filter as well. I was asking because some cartage filters have a check that and if not installed in the proper direction of flow the valves can block flow.
Did you start it? Dumb question, did you loosen or knock the connector for the pressure sender off. If you oil level drops in the sight glass your pump is atleast moving oil.
easyrider
1Bronco's Avatar
July 3, 2009, 07:51 PM
hmm maybe, when i first put oil in it the red oil pressure light was not on. i ran it for like 1 or 2 mins then stopped to recheck the oil level. then i cleaned up, pulled the bike out of the garage and started it and the oil pressure light stayed on at that point.
edit:ill have to check it out tomorrow morning, but where is the connector located? close to the oil filter? and since my bike is a 1996 does it have a pressure sensor or is it just an oil level sensor?
July 3, 2009, 08:49 PM
I've seen the check valve in new filters go bad.
Even if the level was low the pressure light should go out.
Replace the filter.
2008 Honda CRF 450R
Don't ask me,I'm Canadian
C2H5OH's Avatar
July 3, 2009, 09:44 PM
If you did everything right,ride it a while.It's like when you have a car and you don't put your gas cap back on,you get the check engine light.....same thing with bikes.
