» Online Users: 553
4 members and 549 guests
Oil around airbox
Don't ask me,I'm Canadian
C2H5OH's Avatar
Oil around airbox - January 6, 2009, 10:45 AM
Oil around where the throttle body connects to the airbox.Just around one intake,the other 3 are clean.What would cause this?
I'm a llama again!
Slider's Avatar
January 6, 2009, 10:48 AM
Sounds like you have a over filled crank case and your getting blow back.
I'm a llama again!
Slider's Avatar
January 6, 2009, 10:50 AM
You will need new air filters as well.
C2H5OH's Avatar
January 6, 2009, 10:53 AM
D'OH makes sense.I found out after my last time I changed my oil I added 3.75 quarts and that was the overhaul amount,only supposed to be 3 quarts for a regular oil change.I meant to drain out some,but I'm a slacker.
Thanks for the help
Firebreathing VTwin
Dieder's Avatar
January 6, 2009, 10:54 AM
ASSuming your talking about a SRAD750?
I know my TL (same era engineering) had a shitty breather design into the air box. I know alot of guys cap the airbox and run a catch can style crank case breather. I havn't have any issues there.
Check your oil level too. You may or may not need a new filter.
*EDIT*
Nevermind....
First thing learned at MMI... NEVER overlook the owner error factor!
MARK DIEDERICH
Love the one you've got...
I'm a llama again!
Slider's Avatar
January 6, 2009, 11:07 AM
*EDIT*
Nevermind....
LMAO
C2H5OH's Avatar
January 6, 2009, 11:30 AM
More like the owner is an idiot.
