» Online Users: 555
2 members and 553 guests
davidcycle, Slider
Putters at low rpms
I'm legal bitch
badgixxer's Avatar
Putters at low rpms - May 7, 2011, 05:28 PM
Here's the run down... Earlier today, I rolled up to Colemans in Falls Church and on my way there I got stuck in some slow moving traffic on 495. While in this traffic, I noticed the bike would kinda putter at around 3 or 4 rpms in 1st. As I sped up, it was fine.
I just got back in, but while I was out, I figured I would try to duplicate the issue. As sure as shit stinks, it would still putter at the low rpms. Of course I'm in 1st when its puttering, and I would say I'm doing 10 to 15 mph. I could be going faster, but I really wasnt paying attention. I was focused on what was going on.
What could be going wrong?
FYI - 09 Gixxer (duh). 10,500 miles, Full Yoshi exhaust and PCV.
blkr6's Avatar
May 7, 2011, 05:32 PM
coil or plugs in my opinion. i had the same problem with my r6 and i checked everything and it was one of my coils.
2005 Yamaha R6 Raven
1982 Suzuki GS650L
I'm legal bitch
badgixxer's Avatar
May 7, 2011, 05:46 PM
Just had a 7500 service in March (i know - i'm a little late). Plugs were taken care of. Could one have fouled so soon? As you could tell from the question, I'm not all that mechanically inclined.
Your Ad Here
Heist's Avatar
May 7, 2011, 06:11 PM
Sputtering and herky/jerky at low RPMs that disappears when the engine spools up on a FI vehicle is usually indicative of something electrical.
I had that problem on my RC and a remap smoothed it out.
I had that problem on my Volkswagen and it was a bad coil.
A friend had a problem on his ZX-12 and it was a bad plug.
blkr6's Avatar
May 7, 2011, 08:41 PM
spark plug couldnt foul this soon. i would check the coils for spark.
1982 Suzuki GS650L
May 7, 2011, 08:42 PM
is your bike tuned/mapped for the aftermarket exhaust and PCV upgrades? If not, remove them but leave on the decals If it is tuned and mapped, I'm pretty sure your map isn't for low idle cruising
read
understand
read
educate
buy
read
install
read
educate
ride
and this is not a very tech savvy site....IE "check coils for spark" wtf
I'm a secksy boi!
dwnWrob's Avatar
May 7, 2011, 09:14 PM
I just installed my PCIII last weekend and rode for the first time today after install. It's slightly sputtering when I'm stopped, which doesn't seem to be as bad as yours. It never did that before install, and I am running a different map since I have yet to find one to match my slip-on; that is likely my issue. Try what supra said.
'06 GSX-R600
  Send a message via AIM to Send a message via Yahoo to dwnWrob Send a message via AIM to dwnWrob
Leoallafila's Avatar
May 8, 2011, 08:39 AM
There are too many factors that could cause this: dirty plugs, dirty carbs or fuel filter, mapping, electrical gremlin... U need to have someone look at it, there is no way to find out what it is based on your description.
2006 BMW R1200ST
2003 BMW K1200GT (Current)
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2005 Aprilia RSVR Factory
2001 Triumph Tiger 955i
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Suzuki GSX-1100R
1991 Honda Africa Twin 750
2004 Aprilia RSVR Factory
1990 Aprilia Pegaso 125
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
I'm legal bitch
badgixxer's Avatar
May 8, 2011, 10:54 AM
Dammit. I was hoping I wouldn't have to take it in.
I'm not getting how the plugs would be dirty so fast. Just had that done in march.
GiixerFiend7's Avatar
May 8, 2011, 03:18 PM
09 gsxr is fuel injected
change.
Derpetologist
May 8, 2011, 08:21 PM
throttle position sensor need readjusting? has been known to cause the herky jerky at low speed on some bikes
↓ dn ʎɐʍ sıɥʇ ↓
Dark's Avatar
May 10, 2011, 01:56 PM
Remove the PC-V and take it for a spin.
I'm legal bitch
badgixxer's Avatar
May 11, 2011, 02:24 AM
I've actually thought about this as my first action into trying to resolve. My only thing is that #4 plug was a bitch to get to because of the space. I'm off today, so I'll be trying this to see if it fixes the issue.
↓ dn ʎɐʍ sıɥʇ ↓
Dark's Avatar
May 11, 2011, 08:13 AM
It'll be worth the time and effort to know if it's causing the problem or not.
The PCIII was notorious for similar problems and removing the unit would almost always resolve the issue.
If the PCV is in fact causing the problem I would investigate your connections, the PCV harness for damage, perhaps connect to it with the laptop, verify that it's functioning normally, and that it's still storing the proper map (power commanders are known to drop maps).
After it's removed, if the problem remains then do not reinstall the unit until after you discover the problem.
I'm legal bitch
badgixxer's Avatar
May 11, 2011, 11:12 AM
1. Of course it's mapped. Why would I install a PC and not load the map. Wtf?
2. I'm sure the map is for low idle cruising. This just recently started happening. I put the PC last year and load the correct map.
If you had nothing positive to contribute to helping resolve the issue, you should've kept that smart ass comment to yourself.
