» Online Users: 511
3 members and 508 guests
Ran out of gas - Fuel injected
Now with a TBSP of love
Spiritnblk's Avatar
Ran out of gas - Fuel injected - August 26, 2007, 08:15 PM
So, I ran out of gas, refueled (and crossed fingers) hoping it would prime up and start with no problem, but it didn't. I've gone through the threads to see if anyone else managed to do the same, but apparently no one is as as me.
Any help would be greatly appreciated.
P.S. it's an sv650, if that helps.
August 26, 2007, 08:19 PM
Take this as I probably have no CLUE what I'm saying but what I've done to try to "fix" no fuel is turn the bike on and off a couple of times and let the fuel pump prime... starts with no problem. Don't crank over an empty bike or you just get a headache.
Spiritnblk's Avatar
August 26, 2007, 08:24 PM
tried it, but thanks
singin sweet home alabama
DvlsAdvc8's Avatar
August 26, 2007, 09:29 PM
odd - I've run out of gas a couple times and never had a problem starting up again.
Nothing here
Madali's Avatar
August 27, 2007, 05:14 AM
"They" tell you that it can cause problems for FI if you run out of gas and may be difficult to prime, but I think what is more common is that the OP probably sucked some bottom of the tank crud through and possibly clogged the injectors.
August 27, 2007, 11:17 AM
Unlikely because fuel pumps are screened or socked at the bottom to prevent just such an occurance. Also, most of the junk in the bottom of a tank is typically small enough to pass through most older injectors and it is unlikely that he clogged both or that it would prevent the bike from running entirely.
First, establish whether or not you have fuel pressure in the line and that the pump is operating. Once you figure that out that will determine your next step.
skwidrific's Avatar
August 27, 2007, 12:43 PM
having never run out of gas with a fuel injected bike or car, Ben's disclaimer applies here as well. I was told once by a good friend of mine that's a Jeep tech that if i were to run out of gas in my old Cherokee, it would fry the fuel pump. I wonder if that applies here...
2001 GSXR 1000 (The bike that lit the afterburner on the liter class world)
2012 Monster 1100 Evo
2003 Yamaha YZFR6 (track only)
mmm... carbon fiber
Originally Posted by No One Ever
Awesome Prius!
  Send a message via AIM to Send a message via Yahoo to skwidrific Send a message via AIM to skwidrific
Playing in traffic
geezer's Avatar
August 27, 2007, 01:05 PM
I have run out of gas with my '03 SV650 and had no problem restarting. I knew what the problem was, though, and didn't try to start it on empty. Running the fuel pump empty may have blown its fuse, which can be checked by simply listening for the pump with the transmission in neutral, the clutch in, and the key on. If you don't hear it humming away you probably have a blown 10A fuse -- number 3 in the fuse box.
August 27, 2007, 01:09 PM
Hey don't you know someone at a dealer with a service dept you could ask?
skwidrific's Avatar
August 27, 2007, 01:40 PM
wow... that required getting up, walking a few hundred feet, and asking someone... damn dodge!
one of three possibilites:
a) blown fuse, just like geezer said
b) fried fuel pump
c) clogged fuel pump from sucking up any crud that maye have been on the bottem of the tank
mmm... carbon fiber
Awesome Prius!
Spiritnblk's Avatar
August 27, 2007, 08:31 PM
I got it started! After reading some stuff, brainstorming with others and watching this thread (thanks guys!) I decided to try push starting it, causing some kinda combustion. So, after 5 climbs up the hill I heard a new noise . sooooooooooooo I hit the ignition and one of the most beautiful sounds I've ever heard erupted beneath me.
Thanks guys and hopefully this thread will help someone else in the future
By the way.. One thing I did and now know not to do; I did try to start it back up when it first died. I'm guessing that's what screwed me in the first place.
