» Online Users: 499
4 members and 495 guests
rear rim problem help!!!
i suck at the introweb
short_mike's Avatar
rear rim problem help!!! - July 20, 2009, 11:18 AM
ok so i just changed my tires, and come to find a problem in my rear rim. when i went to take the axle out it was abnormally tight i had to drive the axle out the entire way out. changed tires cleaned and regreased inside but now having same problems with rear rim. axle wont go through in the rear rim. axle appears strait, bearing intact. axle will not even slide through the rim off the bike. any suggestions.
Never be afraid that your life will end, only be afraid that it will never begin!
You Learn when your young, and understand when your older!
dsm79's Avatar
July 20, 2009, 11:27 AM
Sounds like a bent axle, or your wheel bearings seized to the axle??? What kind of bike?
July 20, 2009, 11:29 AM
just spit on it....thats what i do when it doesnt go in...
CCS AM # 204
Any corrosion?
That's my guess as to why it was hard to remove.
Is the axle galled now?
2008 Honda CRF 450R
BrianRacerboy's Avatar
July 20, 2009, 11:36 AM
Mike, yesterday I forgot to tell you to take some light sand paper to clean up the axle. Just like Steve says, it could just be corrosion.
-B
short_mike's Avatar
July 20, 2009, 12:09 PM
Originally Posted by SteveZX9 View Post
Any corrosion?
doesn't look like any cleaned up the axle pretty good, its nice and smooth, and yes a fresh thin coat of grease
Is the axle galled now? ??????
Nothing here
Madali's Avatar
July 20, 2009, 12:25 PM
Galling is a process that causes friction when metal parts like nuts and bolts are rubbed together among the high spots on the surface. The friction in turn generates heat and causes the asperities or high points to weld together. It is not the same as cold welding. This is common in metals like steel, where the stainless steel oxide surface breaks down due to direct metal contact. It in consequence leads to solid-phase welding.
Galling causes surface damage and seizing as well as freezing up of the equipment. Galling occurs due to the pressure building up between the thread surfaces of the bolts and nuts in question. Thus it refers to the damage caused to the surfaces of metals due to the sliding contact with each other. Apart from steel this phenomenon is also seen in metals like aluminium alloys and titanium. Galling causes clumps of one part to stick to the other part and break away from the original surface.
short_mike's Avatar
July 20, 2009, 12:29 PM
well, i can tell you the axle is completely out of the rim, no parts sticking to it. from what i can tell it is smooth and the axle rolls smooth as well, but good info thanks
July 20, 2009, 12:31 PM
hit that shit what a hammer...it will go in..make sure ur holding the wheel up at the same time
CCS AM # 204
July 20, 2009, 01:16 PM
Seriously?
Force it in with a hammer?
2008 Honda CRF 450R
July 20, 2009, 01:20 PM
Seriously?
cmon u should know by now not to take me serisoulsy
CCS AM # 204
July 20, 2009, 01:23 PM
True.
If you post it's usually bullshit. LOL
2008 Honda CRF 450R
July 20, 2009, 01:25 PM
True.
i still think he should just spit on it.....that usually werks
CCS AM # 204
Nubbs ban yourself!
n2sport's Avatar
July 20, 2009, 03:38 PM
My suggestion, get new bearings and axle and be done with it.
Some things that control life or death are just better off being right!
To punish and enslave!
2003 GSXR1K
2008 HD Night Train
Originally Posted by Rossi
-Benjamin Franklin
short_mike's Avatar
July 22, 2009, 10:45 AM
thanks B for the sand paper trick. so after finding that it was the left bearing that wouldn't allow the axle to pass through smoothly i took it out cleaned and sanded it til it felt nice and smooth on the inside. after not working the first time i called a few shops and nobody had a left bearing in stock so i went back home this time taking 220 grit and went at it again. now it works. corrosion sure is a bitch didn't even look like it had any nor did i feel any inside the bearing.
