» Online Users: 553
1 members and 552 guests
beatle
rear tire alignment after adjusting chain
dctex's Avatar
rear tire alignment after adjusting chain - May 21, 2009, 01:09 PM
Quick question - my R6 has vertical lines along each side of the swingarm to help ensure that the rear wheel is straight after you've tightened/adjusted the chain.
My question is this - how accurate are those lines on the swingarm? I did the check where you run wooden boards along each side of the rear tire to see if it is straight (in comparison to the front wheel). When I got everything straight/lined up, I'm showing 2.5 lines on the left side and about 2.3 lines on the right.
Thoughts?
Thanks in advance.
Nothing here
Madali's Avatar
May 21, 2009, 01:11 PM
String taped to the undertail and run down each side will show true alignment on the cheap. Also, if you did it yourself, make sure you didn't over tighten your chain or it will bind your suspension.
May 21, 2009, 01:20 PM
Thoughts?
Thanks in advance.
The marks are often not very accurate. String.
dctex's Avatar
May 21, 2009, 01:53 PM
Wait, so how do I run the string? I initially did the string check by taping it to the rear tire and then ran the string from the tire along both sides of the bike to the front tire. I went to using boards because I thought that they were more accurate.
How does it work if I tape string to the undertail? I'm an English major, so bear with me...
I double-checked the tightness/looseness of the chain according to the service manual. Thanks, Madali.
Nothing here
Madali's Avatar
May 21, 2009, 02:06 PM
This may be the easiest and most accurate way. The undertail suggestion is quick and dirty and not very accurate, but still better than the guide marks you're using now.
http://www.ehow.com/how_4584111_chec...alignment.html
T.R.I.T.D.H
TalkofDC's Avatar
May 21, 2009, 02:37 PM
Wait I really don't understand why people don't trust those lines?
I mean hell the bike you're riding is probably one of the finest pieces engineered precision and technology and you're concered that the factory couldn't get tick marks in proper spacing to reflect correct chain/rear wheel alignment?
Geez...not much faith huh?
(sidenote: anybody know if the wear and tear on your chain can cause the alignment to go out of whack? i.e. your chain is old and stretched. You have to adjust the chain every other ride therefore having to use diffrent notches on your swingarm than you typically use with a newer chain. )
Nothing here
Madali's Avatar
May 21, 2009, 02:43 PM
It's on an axis. It doesn't just get aligned front and back. Loosen the nut and wiggle the wheel. You can move it in many different directions, any of which will cause issues. Those marks only account for two points of measurement.
Say Jur Oh
Seijirou's Avatar
May 21, 2009, 02:50 PM
I don't know why. If you really wanted to verify the lines though you can measure from the swingarm pivot to the lines on each side to see if they are the same.
No, wear on your chain will not cause an alignment problem. It doesn't matter which notches or means to measure you use. As long as something on the bike isn't bent, and the rear axle is adjusted equally on both sides, your alignment is fine.
The reason I don't use or recommend other funky methods, such as a strings and boards and stuff, is because now your referencing all sorts of other parts on the bike, any of which could be out of whack. If your point of reference is out of wack, your final measurements are going to be out of whack too but you won't know it.
Greg "BamBam" Walker
September 11th 2009
You are missed
Godspeed
May 21, 2009, 03:09 PM
that's what i was thinkin...cuz my undertail is beat to shit and crooked as hell...guess that only works on newer bikes
a.k.a. Batman?
Madman's Avatar
May 21, 2009, 03:13 PM
eye ball it then do a wheelie. let go of the bars and see which way you fall..
No really..use the marks it fine... if its off you'll feel it..
  Send a message via AIM to Send a message via Yahoo to Madman
jay956's Avatar
May 21, 2009, 11:59 PM
i had the motion pro alignment tool for my old bike, i loved it. now i got a SSS so i dont have to worry about that crap anymore
dctex's Avatar
May 22, 2009, 09:12 AM
Thanks for the replies, folks.
I'm going with the string test that I did (over using the swingarm markers). Here's what Sport Rider magazine had to say:
http://www.sportrider.com/tech/146_0...son/index.html
"Although your bike's rear wheel may seem to be in-line-according to the stamped lines on the swingarm or adjusters-the factory markings are notoriously inaccurate. For years, savvy (and thrifty) riders have used the 'string method' of verifying that their wheels are aligned correctly."
May 22, 2009, 12:36 PM
What if your undertail is not callibrated correctly?
May 22, 2009, 12:38 PM
then u have a deviated rectum...waka waka waka
Say Jur Oh
Seijirou's Avatar
May 22, 2009, 12:51 PM
September 11th 2009
You are missed
Godspeed
