» Online Users: 485
0 members and 485 guests
Removing and reinstalling ignition from triple
Chasing the dragon
okayh's Avatar
Removing and reinstalling ignition from triple - September 2, 2012, 03:21 PM
I need to swap upper triple clamps. How do you remove the safety pins that hold the ignition in place and what other screws from lowes, HD, etc would work when installing it back on the new clamp?
Kawi zx6r if it matters.
More gas, less brake
2 wheels for life
Deep's Avatar
September 2, 2012, 03:53 PM
as far as i remember there is some grinding/drilling involved
Adrenaline Addict
easyrider
1Bronco's Avatar
September 2, 2012, 04:17 PM
What safety pins do you mean? For my Sv you just need to remove two safety lock bolts from the underside of the ignition and it comes off.
Boyo's Avatar
September 2, 2012, 04:18 PM
can you take some pictures?
99 CBR 600 F4 "Black Betty"
05 CBR 600 RR (Stolen)
* Disclaimer - Bad Speller
Chasing the dragon
okayh's Avatar
September 2, 2012, 04:22 PM
That would be smart. I'm on the other side of the state for a few days sadly.
The screws have round heads with no place to put any type of bit. I can see red loctite remnants in the threads of the replacement clamp.
GiixerFiend7's Avatar
September 2, 2012, 10:30 PM
I would notch them with a grinder and use a straight screwdriver. possibly an 18volt impact if they are really tight
change.
ELBOWZ
Jshep's Avatar
September 3, 2012, 09:12 AM
This
CCS #720 Expert
EvolveGT www.evolvegt.com
AMSOIL www.dc-moto.net
James
#1 white rain supplier
Zx6rrection's Avatar
September 3, 2012, 10:04 AM
Yeah agreed
It should've been the same on ur old bike , unless it was removed prior to ur part out
.....yeah once you remove it just take the screw and/or tree to the depot and find some shit that works...u can also go to any auto parts store
Chasing the dragon
okayh's Avatar
September 3, 2012, 02:01 PM
That is smart. I should of undumb myself and thought of that.
Rec, i sold the triple and key set to the same person....no need to separate them.
Chasing the dragon
okayh's Avatar
September 15, 2012, 04:03 PM
bump, fail.
Tried cutting a notch for a flat head and taking an impact to it. No go. Think I'll just remove the whole thing and let someone else swap. I can't be bothered with it ATM...not enough time left to ride!
GDMFSOB
The Evil Twin's Avatar
September 15, 2012, 06:51 PM
From the service manual: Using a center punch, tap one side of the safety bolt head at an angle. Drive the bolt in a counter clockwise direction to loosen.
I believe the bolts are 5mm.
#132 EX
2015 MARRC Crash & Burn Award
September 15, 2012, 07:16 PM
Or just drill straight through the heads of the bolts with a bit the same diameter, or a hair bigger, until they pop off. Then is should be easy to remove the threaded part with some pliers.
September 15, 2012, 08:43 PM
They were probably the torx security screws. It's a torx bit with a little pin hole in it. If you drill the head off, you should be able to remove the last bit of the fastener by hand and be able to salvage the top bridge.
Chasing the dragon
okayh's Avatar
September 16, 2012, 05:54 AM
So...hammer a center punch in at an angle and twist. Really that simple?
Screw em and screw em. Just may just so I can get riding again and not speed money on stuff I don't own (aka center punch)
I know the torx security screws. My steering damper is held on by two. This is not that.
Post mutilation:
September 16, 2012, 07:16 AM
I did a 99 s3. Pretty sure it just used a security bit. Velleman 33 pc. Security Bit Set - Tools - Hand Tools - Screwdrivers
