» Online Users: 553
2 members and 551 guests
davidcycle, Slider
Running Race Plastics on Street
Running Race Plastics on Street - May 21, 2010, 01:10 AM
Legal to do if you can rig up a headlight/brake light setup?
I watch a LOT of gay porn.
  Send a message via AIM to Send a message via AIM to HenryW
May 21, 2010, 02:41 AM
It's plastic. Why do you think one type of plastic would be legal and one would be illegal. Same as color paint, you can do whatever.
May 21, 2010, 02:44 AM
Yeah but is it cool beans to rig up a bright flashlight to the front? Guess I could have articulated a bit better. What is considered "legal" in terms of headlight setup? I assume it's gotta be a little better than some bright flashlights duct taped to the front.
Dude, playing the dude! K
clowe1243's Avatar
May 21, 2010, 02:50 AM
http://www.bikerenews.com/Motorcycle_Inspection.htm
Just have to pass inspection...thats all.
Originally Posted by VA Inspection
Replacement of Stolen/Lost/Damaged Safety Inspection Approval Stickers
The Safety Division issues replacement stickers for lost and/or damaged safety inspection approval stickers under certain conditions, without causing the vehicle to be re-inspected. This process provides a valuable service to those citizens affected by loss, damaged and stolen inspection stickers without compromising the purpose of the Inspection Program. To replace your inspection sticker, contact the Safety Division.
Virginia Motor Vehicle Safety Inspection Program
The Required Official Inspection Procedure, as approved by the Virginia State Police Superintendent, is as follows:
REQUIRED OFFICIAL INSPECTION PROCEDURE
Each inspection consists of the following items – for further details consult the "Official Inspection Manual":
1. - REMOVE OLD INSPECTION STICKER.
2. - DRIVE VEHICLE INTO INSPECTION LANE.
3. - INSPECT BRAKES FOR:
  • Worn, damaged or missing parts.
  • Worn, contaminated or defective linings or drums.
  • Leaks in system, proper fluid level.
  • Worn, contaminated or defective disc pads or discs.
    (NOTE: A minimum of two wheels and drums must be removed from each vehicle at the time of inspection. Consult the official inspection manual for exceptions.)
4. - INSPECT PARKING BRAKE FOR:
  • Broken or missing parts.
  • Proper adjustment.
  • Standard factory equipment or equivalent.
5. - INSPECT HEADLIGHTS FOR:
  • Approved type, aim, and output.
  • Condition of lamp, wiring and switch.
  • Beam indicator.
6. - INSPECT OTHER LIGHTS FOR:
  • Approved type, proper bulbs, condition of lenses, wiring and switch.
  • Aim of fog and driving lamps.
  • Illumination of all lamps, lens color, and condition of lens.
    (NOTE: Every vehicle must have a rear lamp showing a red light to the rear, a white light illuminating the rear license plate; vehicles over 7 feet wide or extending 4 inches or more beyond the front fender extremes must be equipped with approved clearance lamps and reflex reflectors. Count load in measuring.)
7. – INSPECT SIGNAL DEVICE FOR:
  • Correct indications and tell-tale (visual or audible).
8. – INSPECT STEERING & SUSPENSION FOR: (Jack up front end as shown in Manual)
  • Wear in bushings, kingpins, ball joints, wheel bearings, tie rod ends.
  • Looseness of gear box on frame, condition of drag link and steering arm.
  • Play in steering wheel.
  • Wheel alignment and axle alignment.
  • Broken spring leaves, and worn shackles.
  • Shock absorbers.
  • Broken frame.
  • Broken or missing engine mounts.
  • Lift blocks.
9. – INSPECT TIRES, WHEELS & RIMS FOR:
  • Condition of tires including tread depth.
  • Mixing radials and bias ply tires.
  • Wheels that are cracked or damaged so as to affect safe operation.
10. – INSPECT MIRROR FOR:
  • Rigidity of mounting.
  • Condition of reflecting surface.
  • View of road to rear (Truck mirrors must extend at least halfway beyond edge of body) – (Visibility 200 feet to rear).
11. – INSPECT HORN FOR:
  • Electrical connections, mounting and horn button.
  • Emits sound audible for a minimum of 200 feet.
12. – INSPECT WINDSHIELD AND OTHER GLASS FOR:
  • Approved type safety glass.
  • Cloudiness, distortion or other obstruction to vision.
  • Cracked, scratched or broken glass.
  • Stickers. ALL UNAUTHORIZED STICKERS MUST BE REMOVED.
  • Sunshading material attached to the windshield to ensure it does not extend more than 3 inches downward from the top of windshield, unless authorized by Medical Waiver Certificate.
  • Operation of left front door glass.
13. – INSPECT WINDSHIELD WIPER/DEFROSTER FOR:
  • Operating condition.
  • Condition of blade.
14. – INSPECT EXHAUST SYSTEM FOR:
  • Exhaust line-manifold, gaskets, pipes, mufflers, connections, etc.
  • Leakage of gases at any point from motor to point discharged from system.
15. – INSPECT LICENSE TAGS FOR:
  • Illumination of rear plate.
16. – INSPECT HOOD AND AREA UNDER THE HOOD FOR:
  • Operating condition of hood latch.
  • Presence of emissions system -Evidence that any essential parts have been removed, rendered inoperative or disconnected.
  • Fluid levels that are below the proper level
    1. Brake fluid.
    2. Power steering fluid.
  • Power steering belt - proper tension, wear, or absence.
17. – INSPECT AIR POLLUTION CONTROL SYSTEM (1973 and Subsequent Models) FOR:
  • Installation.
  • Operation.
    (NOTE: This includes the catalytic converter and the fuel tank filler pipe.)
18. – INSPECT DRIVER’S SEAT FOR:
  • Anchorage.
  • Location.
  • Condition.
19. – INSPECT SEAT BELTS FOR:
  • Approved type.
  • Installation.
20. – INSPECT AIR BAG AND AIRBAG READINESS LIGHT FOR:
  • Any defects in the air bag system noted by the air bag readiness light, or otherwise indicated; or
  • The air bag has been deployed and has not been replaced (and is not deactivated because of a medical or other exemption and a notice is posted to indicate that it has been deactivated); or
  • Any part of the air bag system has been removed from the vehicle; or
  • If the air bag indicator fails to light, or stays on continuously.
21. – INSPECT DOORS AT THE RIGHT & LEFT SIDE OF THE DRIVER’S SEAT FOR:
  • Handle or opening device which will permit the opening of the door from the outside and inside of the vehicle.
  • Latching system which will hold door in its proper closed position.
22. – INSPECT FUEL SYSTEM FOR:
  • Any part that is not securely fastened.
  • Liquid fuel leakage.
  • Fuel tank filler cap for presence.
23. – INSPECT FLOOR PAN FOR:
(a) Holes which allow exhaust gases to enter occupant compartment.
(b) Conditions which create a hazard to the occupants.
24. – ISSUE STICKER:
(a) If approved, place approval sticker on the vehicle, and give pink copy of certificate to operator.
(b) ALL DEFECTS MUST BE CORRECTED AND THE VEHICLE REINSPECTED WITHIN 15 DAYS.
THE DRIVER MAY BE IN JEOPARDY OF RECEIVING A SUMMONS FOR ANY DEFECT STILL
PRESENT ANY TIME THE VEHICLE IS OPERATED ON THE HIGHWAY.
(NOTE: The validity period of the rejection sticker shall include fifteen (15) days in addition to the day of the inspection.)
NOTE: If you have a specific question with regard to Motor Vehicle Safety Inspection or Inspection Requirements, you can review the safety inspection manual, in part, at MOTOR VEHICLE SAFETY INSPECTION RULES AND REGULATIONS (http://leg1.state.va.us/).
Virginia State Police employees cannot give legal advice, nor interpret the law for members of the public. Information within this Web site is provided for general guidance purposes only and may not apply to all factual situations. Persons needing legal advice may contact Virginia Lawyer Referral Service at 1-800-552-7977 to be referred to a private attorney for a 30-minute consultation for a fee of $35.00.
  Send a message via AIM to Send a message via AIM to clowe1243
May 21, 2010, 05:12 AM
i believe the lights have to be DOT approved....it would say it in raised lettering on the lense itself
CCS AM # 204
Road Kill
JMURACN's Avatar
May 21, 2010, 05:42 AM
I run shark skins with a hole cut out for the stock headlights... It's legit
www.mmsports.org
SJS Customs
Traction Control
Tecknojoe's Avatar
May 21, 2010, 06:53 AM
It's legal, as long as the lights are bright enough. I don't think most flashlights cut it. I also believe it must not be so bright that it is distracting to others.
KTM RC8R
KTM RC390 race
Yamaha R6 race
Honda CRF50 mini
  Send a message via AIM to Send a message via AIM to Tecknojoe
May 21, 2010, 06:54 AM
Yeah my dad got in trouble a few years ago for putting landing lights on the Dodge van he has.
May 21, 2010, 07:02 AM
i was refering to the accual light not the bodywork...hell you dont have to have any bodywork on a bike to ride it...
CCS AM # 204
noise
static's Avatar
May 21, 2010, 07:06 AM
Yep, Venom did it with a flashlight on his old Srad
