» Online Users: 566
1 members and 565 guests
Silkolene Race Oil
Mojito Anyone?
onel0wcubn's Avatar
Silkolene Race Oil - May 11, 2010, 03:38 PM
Has anyone ever used this? I've read a lot of good reviews about it and was thinking to test it out. It's expensive as shit but might be worth a try.
http://www.silkoleneusa.com/default.aspx
http://www.silkoleneoil.com/pdf/ProR0w20.pdf
Pro R 0W-20 Racing Oil
Special formulation, racing only 4-stroke engine oil using Electrosyntec Technology.
Silkolene Pro R 0W-20 Racing Oil is an entirely new concept in competition lubrication. Racing engines lose power and waste
fuel energy due to oil drag and friction. This maximum power 0W-20 is a unique low viscosity synthetic which cuts oil drag yet
maintains a tough low-wear film on highly stressed components. Specially researched friction modifier chemistry depends
upon Electrostatic Adhesion to attack friction at crucial points in valve and power train systems - two sources of hidden power
give that vital edge in acceleration and full throttle output.
Dynamometer tests on 0W-20 advanced development project racing engine oil have produced amazing results. The test
machine was an 1100cc Honda Blackbird motorcycle approximately 1 year old. Power curves were obtained using a 'Dynojet'
rolling-road dynamometer set up to record EEC horsepower. The results were as follows:-
􀂃 15W-50 Racing engine oil:- Max power: 127.9 BHP @ 9750 RPM. Max torque: 75.8 ft-lbs.@
7300 RPM
􀂃 5W-40 Racing engine oil:- Max power: 131.6 BHP @ 9750 RPM. Max torque: 77.7 ft-lbs.@
7400 RPM
􀂃 Pro R 0W-20 Racing Oil:- Max power: 134.4 BHP @ 9750 RPM. Max torque: 78.9 ft-lbs.@ 7400 RPM
These results were much better than expected. In restricted racing classes where modifications are strictly limited, power
increases in the region of 3 to 5% are potentially race-winning!
ELECTROSYNTEC TECHNOLOGY - RELEASES HIDDEN POWER!
Typical Technical Data Pro R
0W-20
Kinematic Viscosity @ 100 oC..cSt 8.91
Kinematic Viscosity @ 40 oC..cSt 45.78
Viscosity Index 179
SAE Rating 0W-20
Cold crank viscosity @-35 oC < 6200 cp
Pourpoint oC <-40
Colour Pale
Amber
Specific Gravity @ 15 oC 0.866
Flash Point, (Closed) oC 180
CAUTION: STRICTLY FOR PROFESSIONAL RACING AND TRACK USE ONLY. SOME OLDER ENGINES MAY HAVE INADEQUATE OIL PUMP CAPACITY
UNDER RACE CONDITIONS TO MAINTAIN FULL OIL PRESSURE WITH THIS LOW VISCOSITY PRODUCT.
The information contained herein is believed to be correct at the time of publication. No warranty, expressed or implied, is given concerning the accuracy of the information or
suitability of the products. Fuchs Silkolene reserves the right to modify and change its products and specifications without prior notice. Full Material Safety Data Sheets are available
on request from the Fuchs Lubricants (UK) Technical Services Department on FREEPHONE 0800 212542 or Tel No: +44 (0)1782 203085
Fuchs Lubricants (UK) PLC Century Street, Hanley, Stoke on Trent, ST1 5HU Tel No: +44 (0)8701 200400 Fax: +44 (0)1782 203775 www.silkolene.com
ay ya yay
May 11, 2010, 04:42 PM
Regardless of what they say, I would run any 20wt oil in my bike if it calls for 50wt.
When that stuff breaks down, it is probably the viscosity of water. Not good regardless of what they say about film strength.
I would like to see some non-sponsored dynographs of the oil comparison.
unapologetic
Hollywood's Avatar
May 11, 2010, 04:47 PM
onelow, what are you trying to accomplish by running this oil? Cooler temps? More power? Extra protection? Longer drain intervals?
asking seriously. It is a really expensive oil and there are a lot of less expensive options out there based on you response. Just because it says "racing" on it doesn't mean it's the best stuff for your bike, just keep that in mind.
"ride on #47, ride on"
AMSOIL/NGK Dealer
DC-MOTO's Avatar
May 11, 2010, 05:49 PM
Stick with Amsoil
CCS #133 AM
For all of your oil and filtration needs go to www.dc-moto.net
  Facebook Page Send a message via AIM to Send a message via Yahoo to DC-MOTO Send a message via AIM to DC-MOTO
The last urrbendah
Stillie's Avatar
May 11, 2010, 05:56 PM
Fuck that noise. Type R means everything in these streets.
13 KTM 200 XC-W
15 KTM 350 XC-F
Being nice :)
ziggy's Avatar
May 11, 2010, 06:10 PM
Fuchs? what the fuchs?
Rotella Synthetic ATW ! btw
You're Welcome...
Mojito Anyone?
onel0wcubn's Avatar
May 12, 2010, 09:18 AM
I think I just want to try a different oil for my bike to see the response that I get. I have tried numerous oils from rotella to repsol.. amsoil being the latest. I'm not necessarily looking for cooler temps or more power.. I know there won't be extra protection or longer drain intervals with this oil. I'm also smart enough to know that anything that says racing on it isn't always needed..
I was just reading around some kawi forums and a few people raved about this oil and how they had improved performance while using it.
ay ya yay
STAY ON THE BIKE.........
SickRick's Avatar
May 12, 2010, 10:39 AM
silkolene is really good oil...ive always ran it in my bikes and i love it...again it is a lil pricey but for what it is its great..i mean we spend thousands of dollars on our machines and aftermarket performance..why not spend the lil extra where it really matters!
May 13, 2010, 12:54 AM
Because that extra money does not necessarily buy your extra protection. Plenty of overpriced MC specific oils out there sold at shops that under deliver when compared to other oils.
I can run off the shelf Rotella, Mobil 15w-50, or AMSoil at about 6 bucks or less a quart and have a better oil that most so-called MC oils.
I see no data as to what base stocks they are using and unless you run very short intervals on a low viscosity oil like that, you are asking for problems.
I would prefer to have a safe motor than one that makes about 2 more HP and cost a sh*t ton more to run.
2 wheels for life
Deep's Avatar
May 13, 2010, 08:42 AM
oiloiloiloiloilololololol
Adrenaline Addict
SickRick's Avatar
May 13, 2010, 10:58 AM
the silkolene pro comp 4 10w40 is the best stuff ive ever ran in my bike is all im saying..to each is own but i back silkolene 100%
