» Online Users: 566
1 members and 565 guests
Some type of electrical issues......need help please
i suck at the introweb
short_mike's Avatar
Some type of electrical issues......need help please - August 7, 2010, 10:27 AM
Ok so i am having problem with my bike and need some suggestions here is whats happening:
Bike rides fine then out of nowhere bike cuts out (no matter what gear or speed could be cruising to work at 80mph), but does not loose power its as if i hit the kill switch. since bike is moving it push starts itself i grab the clutch and rev the motor and it revs up soon as i let go of throttle it cuts out.
At this time no FI codes are blinking. Here is what happens on the gauges:
Riding then FI light comes on, then red light turns on completely solid with no blinks, then bike cuts out and oil light comes on. I hold in the clutch let the bike cost FI light turns off i start it up while still moving then let go of clutch and ride normally then about 1 min or less later does it again and does this continuously. If i come to a complete stop it will not stay running.
The ride does not start off like this the bike will run fine for about 20min before doing this. Then when the bike sits for a bit (say while i am at work) it will run fine for the first 20min and do it again.
i checked the code book and nothing is coming up with this sequence. I checked my battery and it was not holding power when it had a load against it so i thought it was robing power from the stator (stator is putting out proper volts) so i put a brand new one in ,but no luck. So then i thought it was the bank angle sensor (tip sensor) so i bypassed that, and now it runs fine for the first 40min, but still doing the same thing. I have also noticed that the bike temp fluctuates between 170 and 180 (even while i am cruising) more often then it use to usually staying at 180 (usually it runs around 178 continuously when i am just cruising to work).
any suggestions i am stumped, oh and i ride a 929.
Never be afraid that your life will end, only be afraid that it will never begin!
You Learn when your young, and understand when your older!
August 7, 2010, 10:36 AM
This may sounds totally juvenile and obvious..but are your battery leads tight and clean?
2018 XSR700
August 7, 2010, 10:37 AM
Ride around with a voltmeter connected to the battery and keep track of how the voltage varies at different RPM and as the bike gets hotter. Then report back.
short_mike's Avatar
August 7, 2010, 10:59 AM
yes, but thanks for the input anything will help at this time
short_mike's Avatar
i will try what feed back could that lead too?
August 7, 2010, 11:03 AM
If the electrical system is working properly.
where the good spotz at ?
kidcycle's Avatar
August 7, 2010, 11:04 AM
check your kickstand switch .... might be jiggling while you ride
DBR 4 Life
August 7, 2010, 11:06 AM
I suggested this due to my own misdiagnosis about 10 years ago. Same symptoms. I slapped myself after figuring out what it was.
2018 XSR700
short_mike's Avatar
August 7, 2010, 12:18 PM
this is true but it wont stay running at a stand still when it starts acting up and if the kickstand sensor was going off it wouldn't allow the starter to fire.
Say Jur Oh
Seijirou's Avatar
August 7, 2010, 12:28 PM
My guess is the ignition module is going bad and gets flaky when it gets hot.
When you have some time with a cold bike, start it up and take a hair dryer to the ignition module while it's idling and see if you can get it to cut out earlier than usual.
Greg "BamBam" Walker
September 11th 2009
You are missed
Godspeed
Got Any Gwapes?
boomboom929's Avatar
August 7, 2010, 01:02 PM
I, myself, have a ton of street and track miles on 929's. My 929 started having electrical issues and I chased each one diligently. Something didn't add up, it kept happening. I kept looking for the cause and finally found it at 2am one night, a common grounding block in the wiring harness. Down the right side of the frame the main harness has a grounding block and mine was corroded. I tried to clean it and such but to no avail. I finally put a main harness on it and ALL of my "Ghosts in the Machine" disappeared. I've seen it no less than a dozen times and installed 5 harnesses myself, including mine.
Go look, you'll find it. It's about the size of a small box of matches wrapped in electrical tape in a lump on the harness on the right/throttle side below the throttle bodies...
*GODFATHER*
Flores703's Avatar
August 7, 2010, 01:25 PM
if you have a bypass on your kickstand its your relay
08- 99 cbr f4---sold
08-05 r6 --- sold
08-03 streetfighter cbr rr crash need parts
super pucket bike x19
11- 06 zx6r 636
short_mike's Avatar
August 8, 2010, 11:32 AM
short_mike's Avatar
August 8, 2010, 11:33 AM
thanks will definitely check that out
short_mike's Avatar
August 8, 2010, 11:34 AM
is it attached to anything? where would the corrosion be if there is any? and i like your wording "ghosts in the machine"
