» Online Users: 569
0 members and 569 guests
Spark plugs opinions please
Space's Avatar
Spark plugs opinions please - September 22, 2008, 03:31 PM
I need to replace my plugs. Do I stay with the good ole NGK copper or go with something different? What about changing heat ranges? I know nothing when it comes to this.
Bosch paltinum 4?
Irridium?
E3?
Basically I want the most efficient plug I can get. I want something that will burn the most amount of fuel possible. I am leaning toward the E3 because they claim to make more power using less fuel or so the video on their site claims. Also, would like something that may last a little longer. My bike is not high reving normal cruising rpm is 4500 if that makes a bit of difference.
This Ain't My First Time!
cf3232's Avatar
September 22, 2008, 03:54 PM
I would get the NGK Iridium tip. They are a harder metal and last longer the finer end is claimed to reduce fowling and is claimed to give a stronger spark because it is finer.
~Blutarski~
Dodge131:
September 22, 2008, 04:00 PM
Ive always been tempted to go away from the standard copper the bosh quad plat, e 3 NGK iridium.
Alas I find it to be too costly.
Space's Avatar
September 22, 2008, 04:08 PM
E3 are $6 each and I only need 3. I put the Bocsh in the Camry and gained 1MPG whooopie
cf3232's Avatar
September 22, 2008, 04:42 PM
Are you talking about spark plugs for the car or motorcycle? If you are talking cars I always use Bosch platinum 4 and have great results with them. I tend to get great gas milage when using them. 26 MPG in the Ford Ranger 1998 4 cyl.
~Blutarski~
Dodge131:
forceofnature's Avatar
September 22, 2008, 04:59 PM
If you heare anything about Brisk racing plugs dont use them I have had two bad sets so far on my bike.
Forceofnature
___________________
2006 Red/ Black Suzuki Hayabusa
Which is worse: ignorance or apathy? Who knows? Who cares?
It's easy to identify people who can't count to ten. They're in front of you in the supermarket express lane.
Imagination is a quality given a man to compensate him for what he is not, and a sense of humor was provided to console him for what he is.
September 22, 2008, 05:11 PM
A 1mpg difference can easily be attributed to something as simple as air temperature. This was very evident on my trip to Barber. I gained several mpg later in the trip on my second tank of gas when it was hot compared to the first tank which was burned up when it was 20-30 degrees cooler.
Standard NGK work just find. I've compared standard ones to iridium on the dyno. No difference.
Retired to most ...
JohnnySpeed1KRR's Avatar
September 22, 2008, 05:27 PM
Standard NGK if it's available to you. You're not going to see more power or better fuel economy based on plugs. I of course am screwed and required to use iridium plugs.
Space's Avatar
September 22, 2008, 06:06 PM
bike. Thats what I put in the Camry. Still getting 30+ mpg at 241k.
Space's Avatar
September 22, 2008, 06:09 PM
Thanks.
I'll stick to the NGK. They are cheap. I don't really care if I gain power, only economy and longevity.
Space's Avatar
September 22, 2008, 06:13 PM
Thanks
Advance carries them for cheap.
