» Online Users: 153
4 members and 149 guests
Tire tube questions?
Knarly Adventurer
wildjester's Avatar
Tire tube questions? - May 16, 2012, 11:10 AM
For you dual-sport/endure/adventure riders... whats up with tubes?
I'm replacing the tires on my Scram. (2009 w/ 4500 mls)
What do I need to know?
Should I get new tubes?
Are the cheaper bikemaster tubes ok?
If it doesn't need replaced, should i at least have one on hand in case I damage one mounting?
What else?
Thanks!
2013 Triumph Tiger 800XC
2009 Scrambler SOLD
2007 ZX14 SOLD
2005 R1 SOLD
1999 ZRX SOLD
1996 FZR SOLD
Derpetologist
May 16, 2012, 02:00 PM
http://www.supermotojunkie.com/showt...ing-tire-tubes
May 16, 2012, 02:05 PM
Yes put in new tubes everytime. Keep the old ones as spares. If you are doing it get an extra set. The bike master ones will work fine. Get good spoons and windex.
Derpetologist
May 16, 2012, 02:31 PM
Dodge do you know of any decent, inexpensive wheel mods / conversions to go full tubeless?
I hate Hybrid drivers
david636's Avatar
May 16, 2012, 02:40 PM
I change lots of tubed tires. I always use new tubes. There are prolly 2 nuts on the valve stem. One goes on the inside of the rim, one goes on the outside. I have seen so many wheels with both on the outside. Use lube, I use simple green, it's very slippery on rubber and water soluble. If the tires are stiff I put mine in the kitchen oven for a few minutes at the lowest setting, usually 100 degrees. I also recently got a couple tire spoons from Motion Pro.
Motion Pro - Tire Iron Curved 16 Inch
Knarly Adventurer
wildjester's Avatar
May 16, 2012, 02:43 PM
Changing with no-mar so should go fast and easy.
Thanks for the tube info. I'll pick up a new set.
2009 Scrambler SOLD
2007 ZX14 SOLD
2005 R1 SOLD
1999 ZRX SOLD
1996 FZR SOLD
david636's Avatar
May 16, 2012, 03:01 PM
Cheater
Knarly Adventurer
wildjester's Avatar
May 16, 2012, 03:13 PM
Originally Posted by david636 View Post
Cheater
haha!
So the tube size I order just matches the wheel size right?
Like my front wheel is a 2.5x19... so I order tube for 2.25/2.5x19
correct? Seems logical enough, but ya never know.
2009 Scrambler SOLD
2007 ZX14 SOLD
2005 R1 SOLD
1999 ZRX SOLD
1996 FZR SOLD
KirkRoy's Avatar
May 16, 2012, 03:58 PM
Heavy duty ones will survive thorns better. I like to do rim strips at the same time too. Cheap insurance, IMO.
