» Online Users: 197
4 members and 193 guests
nootherids, R6SP, RRonin, Sal_the_man
Why LEDs not working on trailer?
RADAR Magnet's Avatar
Why LEDs not working on trailer? - June 8, 2013, 03:47 PM
I picked up a bunch of LED lights from Restless Wheels for my trailer today; popped them in and some worked while most didn't. The brake lights and the running lights on the fenders worked fine, but every light on the body did not work. I tried reversing how I inserted them and that did nothing. I replaced one with the old incandescent light and it worked fine.
I'm going to take the trailer over there Monday so they can play with it; worst case I just put incandescents on but figured I'd post up here just to see if anyone has any ideas. Thanks.
05 CBR600RR
June 8, 2013, 03:53 PM
First thing that comes to mind is polarity. Unlike filiment bulbs, LEDs will not work with polarity reversed.
watch this!...
1is2many's Avatar
June 8, 2013, 03:59 PM
Bad ground, trailers rust quick.
June 8, 2013, 04:04 PM
I wondered about this; thought maybe I had all of them in backward; tried reversing one of them but it still didn't work.
I must not understand something. Why would that impact the LEDs and not the incandescents?
05 CBR600RR
Im Always Down to Ride
bds120's Avatar
June 8, 2013, 04:10 PM
I would say probably need to get resistors. I have these and they work awesome.
Speed kills, ride a Yamaha!
June 8, 2013, 04:29 PM
If the lights he picked up aren't designed for 12 volts then resistors would be a great investment! But even if they are lower voltage LEDS without internal resistors they should still light up.
June 8, 2013, 04:31 PM
I guess the first question really should be: Do the new LEDS work if you connect them to a 12V source?
June 8, 2013, 04:43 PM
And just like that you and bds120 have exceeded my knowledge. I know nothing about resistors but am happy to test if a 12v will power them, if you explain how to do that and I have the right stuff.
FWIW, the guy at the shop looked at my trailer and picked out the lights. I called him and he is puzzled; will check out Monday if not solved before.
05 CBR600RR
June 8, 2013, 05:35 PM
Can you snag a picture of the bulb off the net? A model number would be helpful too.
As far as testing it's just a matter of taking a couple of jumper wires from a 12V source and connecting the bulb. If it it has a round metal base touch the ground wire to the side of the metal base and the +12v power wire to the shiny metal button on the bottom of the bulb.
Re: Why LEDs not working on trailer?
bds120's Avatar
Re: Why LEDs not working on trailer? - June 8, 2013, 08:03 PM
Basically what I'm saying it all you do is place those resistors between the connectors. Like I use bullet connectors and put them on the ends of the resistors. You basically just put them between the connections. Very simple.
GDMFSOB
The Evil Twin's Avatar
June 9, 2013, 07:52 AM
+1 to pictures.
You can use a 9 volt battery to test them. Makes it easier than using your car battery. Ignore the resistor in the photo, your lights will have an internal resistor. Because an LED is a diode, polarity is important so try connecting both ways. I have found LED's that were reversed from what was marked. Fucking Chinese shit.
#132 EX
2015 MARRC Crash & Burn Award
