» Online Users: 546
3 members and 543 guests
Yay! my bike won't start and I'm at VT :D
VTMC Rider
MegaTorch7's Avatar
Yay! my bike won't start and I'm at VT :D - September 10, 2008, 12:57 PM
So last night I decided I would go get some wings at a local joint down here Blacksburg (40cent wings at Bdubs night ). As soon as I pulled into the parking lot the bike cut. the first thought was, "I know I didn't stall... shit im probably out of gas" so I called up a buddy to drive me over to the gas station we got a liter of gas(aquafina bottle=ghetto) that didnt start her up so we went and got another...
That's when I realized it, the bike was not making the usual *whirring* noise as I flicked the kill switch to on mode. I'm starting to think that 1. The fuel pump is dead or 2. possibly the relays after talking to my normal mechanic
any ideas for pinpointing the problem. I'm at school so I dont have a truck or ramps and I'm incredibly far from my usual shop, I do however have a tool set down here so thats a start I suppose. If you know any hokies that could help move a bike have them give me a call as its currently just accumulating tickets in the commuter lot. phone = 703.509.1011
thanks for the help guys
Riding is good for the soul
- Honda CBR 929rr
- Ducati 1198s
  Send a message via AIM to Send a message via Yahoo to MegaTorch7 Send a message via AIM to MegaTorch7
September 10, 2008, 01:11 PM
Call the guys at duncan honda down there they are really friendly, myblue750 is at Tech shoot him a message.
September 10, 2008, 01:20 PM
Check the wiring. It is likely that the kickstand switch or other related ignition switch has come loose.
Retired to most ...
JohnnySpeed1KRR's Avatar
September 10, 2008, 01:22 PM
I just had the same issue on my 954. Turned out to be faulty wiring in the kill switch housing.
Play with the kill switch a little bit and if need be pull it apart and check the conncections.
ATTN INVESTORS!
rekoniz's Avatar
How old is your battery? Did you check fuses?
  Send a message via AIM to Send a message via AIM to rekoniz
making it do what it do!!
MANIMAL's Avatar
September 10, 2008, 01:32 PM
do you have the bike in neutral??
  MySpace.com Page Send a message via AIM to Send a message via AIM to MANIMAL
VTMC Rider
MegaTorch7's Avatar
September 10, 2008, 01:41 PM
it seemed to be working last night from what I can remember the red light would come on and go off like it was supposed to when I flicked the switch
- Honda CBR 929rr
- Ducati 1198s
VTMC Rider
MegaTorch7's Avatar
September 10, 2008, 01:43 PM
the battery is strong and I checked all the fuses last night, its thowing the starter with out issue, we even tried to push start it. I'm almost positive its a fuel issue because durring push starts you could hear the motor turn but it was like it wasnt getting any gas, just pushing air through the cylinders
- Honda CBR 929rr
- Ducati 1198s
VTMC Rider
MegaTorch7's Avatar
September 10, 2008, 01:48 PM
haha yes its in neutral, this isnt my first bike lol
- Honda CBR 929rr
- Ducati 1198s
The last urrbendah
Stillie's Avatar
September 10, 2008, 01:52 PM
Tipover sensor? Had one fall off the mounting point on the undertray once and created the same issue you're describing.
13 KTM 200 XC-W
15 KTM 350 XC-F
September 10, 2008, 02:17 PM
Side stand switch? Clutch switch? Is starter moving?
Put in N
Kick stand up
Pull in clutch
Try to start
September 10, 2008, 02:39 PM
Check the clutch switch. If it came loose, it won't start even if you pull in the clutch. I'm not all that fimiliar with 929's but I assume most bikes are similar. Anything happen recently? A drop? Other damage?
Sounds like there is no power to the fuel pump, so if all the safety switches and fuses are fine, then it sound like a fuel pump issue, so check those connections as well.
September 10, 2008, 02:41 PM
Do you have any power? Lights, dash, etc?
Given the fact you mentioned using the kill switch I'll assume you use it a lot. If so it's certainly up there on the suspect list. A lot of MC kill switches are not rated for constant use. That's what the ignition switch is for.
The fact that the bike died while running makes me think fuse though.
VTMC Rider
MegaTorch7's Avatar
September 10, 2008, 03:50 PM
I'm going to go work on it tonight, going to start by running a hot wire to the fuel pump to see if its even working at all then i guess ill go from there
power is good, fuses are good. Ill check for the tip over sensor as well
the starter does crank though, also I did not know kill switchs were not rated for everyday use, I always kill the bike before i park it, it's a habit i gained from the first time i took MSF
- Honda CBR 929rr
- Ducati 1198s
VTMC Rider
MegaTorch7's Avatar
September 10, 2008, 03:51 PM
thats exactly what I am thinking right now
- Honda CBR 929rr
- Ducati 1198s
