» Online Users: 528
3 members and 525 guests
ZX9 Tachometer question........
Aboogie's Avatar
ZX9 Tachometer question........ - August 17, 2010, 09:15 PM
Finishing up the 99 to 00 Conversion and I am running into one last issue with the gauges......
I have everything wired up, but now when the bike is started the tach stays at 4000 rpm. And when I rev it, it always stays 4000 rpm above the actual rpm....
Do you have any thoughts on this issue..........
http://twitter.com/Aboogie301
RIP Weezie aka GODSON............
Dude, playing the dude! K
clowe1243's Avatar
August 17, 2010, 11:18 PM
Interesting...maybe a speedo change required?
  Send a message via AIM to Send a message via AIM to clowe1243
Aboogie's Avatar
August 18, 2010, 08:11 AM
Im looking into that now.......
I had to change up the wiring a bit during the swap so I am going to fool around with that some more....... Here is the model that I followed.......
C Loom Pin
1. move to 15. Black yellow. Chassis earth.
2. move to 14. Turquoise (V Light green). Neutral Indicator light.
3. move to 6. Red black. High beam indicator.
4. move to 5. Grey. Right hand turn signal.
5. move to 4. Green. Left hand turn signal.
6. move to 3. Blue red. Oil pressure warning light.
7. move to 2. Empty
8. move to 1. Light blue. Tacho Pulses from IC Ignitor Unit.
9. move to 16. Red blue. Tacho and Speedo illumination.
10. move to 7. White. Always live 12 volts use not known maybe Clock.
11. move to 8. Brown white. 12 volts to Oil, Neutral, Tacho, and Speedo.
12. move to 13. Pink. From Speedo censor, use not known.
13. move to 12. Black blue. Earth for Tacho, Speedo and Coolant overheat warning LED.
14. move to 11. Empty.
15. move to 10. Blue. Coolant overheat warning LED.
16. move to 9. Yellow. Speedo pulses, from Speedo sensor.
August 18, 2010, 08:23 AM
You might have to put in a resister. Funny it should work fine. I have a 94-97 gauge package from a ZX9 on my 2001 ZRX and it plugged right in and worked perfect.
Aboogie's Avatar
August 18, 2010, 08:29 AM
Is this Rick? I was told to call you on this issue........
I will try a resister......
A buddy ,who has also done the conversion, said the wiring worked perfectly for him so I am wondering if its another issue.........
August 18, 2010, 09:43 AM
Nope not Rick. Do you have a bad ground? It should work unless something is miss wired or damaged.
Aboogie's Avatar
August 18, 2010, 09:58 AM
I dont think I have a bad ground, but I will check it..........
Aboogie's Avatar
August 18, 2010, 10:59 AM
What ohm resistor do you suggest???
