» Online Users: 568
4 members and 564 guests
BlackHatch, davidcycle, GRN96WS6, onel0wcubn
electrical prob=(
Landshark
westmonty's Avatar
electrical prob=( - March 7, 2009, 10:26 AM
hey im blowing a fuse lately everytime i start the bike. It could be the starter but im not sure what im looking for when i prop up the tank....anyone with some clues or can help much appreciated.
  MySpace.com Page Send a message via AIM to Send a message via AIM to westmonty
March 7, 2009, 10:34 AM
What bike? What fuse?
Landshark
westmonty's Avatar
March 7, 2009, 10:54 AM
06 gxsr1000, its the head on fuse possibly the starter
March 7, 2009, 10:58 AM
gixxer.com
do a search on that site....some amazing shizznit
u'd have an answer already....not doubting the above poster's skills at all though...just sayin.
scroll down past the box and see if these help. I ran a search using "head on fuse GSXR 1000"
http://www.gixxer.com/forums/gtsearc...gsxr+1000#1505
March 7, 2009, 11:09 AM
You might have better luck calling it the main fuse. You can also rule out the starter by disconnecting it and turning the key on and press the start button and see if the fuse pops. If it still pops then its not your starter.
Your dirty Uncle
pokey's Avatar
March 7, 2009, 03:30 PM
If the starter works and the bike starts, ot is not the starter. Head usually means headlamp. Check an owners manual, make sure you are looking at the right fuse.
Electricity is LAZY!!! think of it like water, It takes the shortest path to ground.
Water will not go around the mountain when it can go straight down the mountain.
This can mean you have a pinched wire (short to ground) which is causing too much current flow and blowing your fuse.
If the circuit has a bad ground your fuse will also blow. If the circuit in question shares a ground with the starter that is bad(ground) you may have found a problem.
" Fire Fire Fire"
David " what happens if you look at them?"
Pokey " I don't know, I've always avoided eye contact..."
David " Hello, my name is David and I turned to stone."
