» Online Users: 497
3 members and 494 guests
GRN96WS6, MPSniper, Toecutter
HOW-TO: Maintain your Brakes (Pads + Bleeding)
Addicted to Cajen food...
LaoTzu's Avatar
HOW-TO: Maintain your Brakes (Pads + Bleeding) - February 21, 2006, 02:08 PM
How-To Revitalize and Maintain Your Disc brakes
By Michael Kresnicka
Torrance, California, October 30, 2000 --
Most of us can't afford to run out and buy a new bike every time something goes wrong or needs adjusting. So as consumers, we are familiar with the ever-so-painful and expensive trip to the local dealership or mechanic.
You may have pondered the idea of performing simple maintenance tasks on your own, but may be overwhelmed with questions and the possibility of making things worse than they already are. Well fear no more because when it comes to disc brakes, they're all pretty much the same and reasonably easy to tackle by the average do-it-yourselfer. However, you must use a great deal of caution when dealing with brakes because of how important they are to safety. If you don't feel comfortable working on your brakes by yourself, then by all means have someone with more knowledge and experience help you.
Whether you ride a sportbike or a modern cruiser, the elements in the braking system are pretty much the same. They all take advantage of a fluid element that is pressurized to provide the required forces (better known as hydraulics) to squeeze the brake pad material onto the rotor. As easy as this sounds, there are a few key tricks to making sure that your brakes are up to spec.
First and foremost is making sure there is no air in the hydraulic system. Air is your enemy and can get you into serious trouble if the necessary precautions are not taken. The second most important aspect of your motorcycle's braking system is the amount of friction material on your brake pads. As you use your brakes, the material is slowly burned away in order to provide enough friction to stop your motorcycle. The third most important aspect is the condition of your brake fluid. Brake systems are not set-and-forget items on your bike. As the fluid gets old, it starts to degrade and absorb moisture, reducing its ability to perform its job.
Replacing stock or worn brake pads is the quickest way to get increased braking power out of a tired system. Various manufacturers make all kinds of different types of replacement brake pads for today's motorcycles. Some claim to last longer, while others claim to give more feel and braking power. However, be forewarned that the manufacturer of your motorcycle put a lot of time and effort into developing your braking system, and there is no telling what a different type of pad material might do to your rotors or how well different pads will work with the overall design and setup of your bike. If you have any doubts, then stick with genuine factory parts.
EBC "Double-H" Brake Pads
EBC's Standard "Black" Kevlar Pads
I chose to forego my own advice and try a set of EBC "Double-H" Sintered Brake Pads on the front brakes, which claim to be nice on your rotors and still provide massive stopping power over the stock setup. However, on the rear brakes I choose not to upgrade to a better pad material simply due to the fact that the rear brakes are way more sensitive to locking up the the fronts, and replacing your stock rear pads with an upgraded type can provide too much initial bite and get you into some serious trouble. So, I chose to stick with EBC's "Standard Black Kevlar Pads" in the rear.
Removing the calipers from the rotors is the first step in checking your brake pads. In dealing with your front disc brakes, first remove the Front Caliper Mounting Location two main bolts that attach the calipers to the forks. Notice the bike I am working on has floating calipers and floating discs. The floating disc allows the inner portion of the disc mounting system to be made from a lighter, weaker material and hence decrease the rotating mass of the wheel and adding to the overall lightness of the motorcycle. The floating calipers pivot back and forth as pressure is applied to distribute the forces evenly over the two pad materials and keep the pads in full contact with the rotor during the entire braking process. Once the calipers are free you can slide them off of the brake discs and inspect the amount of pad material and look for anything out of the ordinary. If there is less than 1/8 inches of pad thickness left then they should be replaced.
Internals of Front Caliper
Once the calipers are free from their mounting locations, it is time to disassemble them and remove the brake pads. On this particular setup there is one threaded metal pin that holds one side of the pads in place. The other side of the pad rests in the casting of the brake caliper. Removing this pin will free the pads and they should just fall right out. Notice the metal clips inside the caliper just beneath where the pads sit. These metal clips provide pressure on the pads to keep them from moving around inside the caliper. It is a good idea when you are working on your brakes to replace these clips. It would be foolish if you spent all this time and effort to have something so simple and cheap screw things up.
Rear Caliper Mounting Location
The rear brake assembly is similar to the front brake assembly. However, on this particular bike the rear disc is solidly mounted to the wheel and isn't of the "floating" type as the front discs. The caliper, on the other hand, is of the floating type. Removal of the rear caliper required me to remove my slip-on muffler and unscrew the two mounting bolts holding the caliper to its mounting bracket, located over the swing arm. Notice that the caliper-mounting bracket has room to slide back and forth as you tighten or loosen the amount of slack in your chain. This provides the entire brake mechanism to slide with the rear wheel in order for the pads to stay in full contact with the rotor when the chain is adjusted.
Internals of Rear Caliper
Once the two mounting bolts have been removed, the caliper should easily slide off the rotor. Inspection of the pads is the same as the fronts. Notice that this caliper has only one piston forcing the pads together as opposed to the two pistons on the front calipers. The rear pads are smaller because less braking power is required. The rear pads are held in place by one bolt on one side of the caliper and are held at the other end inside the casting of the mounting bracket that the caliper is bolted to. Be very careful to make sure the new pads are firmly mounted in the caliper and are held securely at both mounting locations. If there is any doubt, check them again! Otherwise, they could fall out while you are cruising down the side of your favorite canyon road and ruin a perfect day, causing you to crash into the guard rail and go flying off the side of a cliff. Not a pretty site.
Once the new pads have been assembled into the calipers and everything is torqued to spec, it is time to bleed the lines. In order for the hydraulic brake system to function properly the entire system must be fully pressurized without any air or moisture. If air and/or moisture are present in the system, it can cause a "soft" or "spongy" feel to the pedal when applied. Air can really mess things up, as it is compressible and can allow excessive pedal travel and loss of braking pressure. Moisture in the fluid will boil causing the same conditions and will also contribute to corrosion of internal brake components.
There are several different techniques to bleeding brake lines. Some of the more popular ideas are outlined below.
The Old Fashioned Way
This method of bleeding your brake system can work if you absolutely don't want to spend any money to make things easier on yourself. The basic idea is to have two people, one puts a light amount of pressure on the brake lever to introduce pressure into the system while the other opens the bleeder screw on the caliper and closes it after a couple seconds, thus purging the system of a little bit of fluid and air. As easy as it sounds, it is very difficult and time consuming to completely flush out all of the old fluid and the air bubbles from the system without getting out of sync with your partner and sucking more air into the system.
The Easy Way
For not a lot of money one can purchase a couple simple devices that will ease the painful process of brake bleeding. The first (and cheapest) is a simple little spring operated valve mechanism that attaches to a plastic hose from the bleeder screw on your calipers. This valve acts as a one-way bleeder that lets fluid and air out and closes before outside air can be sucked back into the line.
Hand Operated Vacuum Brake Bleeder
The second method is a vacuum bleeder that also attaches to the bleeder screw on your caliper. However, this has a hand operated pump that sucks fluid through the system, making the entire process of changing fluid extremely easy and assuring that very little air is left in the system. The vacuum bleeder costs anywhere between $28 and $100, depending on how nice of a vacuum bleeder you want.
Since I like to be as efficient as possible, I opted for the vacuum bleeder method. I purchased the MityVAC Vacuum Brake Bleeder for $28 from my local automotive parts store. It essentially is a hand-operated pump with a small reservoir attached to collect the old fluid. There are more expensive and sturdier units available. But I don't intend to use this often (maybe a couple times a year), so I figured the cheap one would do fine.
Motul Racing Brake Fluid
Once you have selected a method that works for you, it's time to go buy the best brake fluid that you can afford. There is no sense in spending all that time and money only to use a bargain brand of brake fluid. There are many good brands of brake fluid. I opted for a bottle of MOTUL "Racing Brake Fluid 600" for $12.00 from my local motorcycle dealer. This is often regarded as the best brake fluid for any application. It is a DOT 3,4, & 5.1 compatible synthetic fluid that has an incredibly high boiling point and excellent thermal stability. Any brake fluid is extremely poisonous and corrosive and will suck the moisture out of your skin, so wear some rubber gloves when working with the stuff. It will also eat right through the paint on your motorcycle, so be careful and use towels around the master cylinder reservoirs. With moisture in mind, you want to minimize the amount of time that the fluid is exposed to air to prevent it from absorbing any moisture that will lead to poor brake performance. My advice is not to open the seal on the bottle until you are ready to use it and keep it closed immediately after you are done with it.
My intent was to completely flush the old fluid out of the system and replace it with the new stuff. I used a turkey baster in order to suck all the old fluid out of the front and rear master cylinders. If you don't own one, then go to your local grocery store and buy one. It sounds stupid, but they work great.
Once you have sucked out all the old fluid, pour your new fluid into the master cylinder and begin to bleed the system. If you choose to use a vacuum brake bleeder as I did, keep in mind to read all of the instructions carefully. I had very little trouble using my vacuum bleeder, in fact the entire process took less than 15 minutes to finish. Life is so much easier when you have the proper tools.
Keep in mind to watch the level of fluid in the master cylinder as to not let it get too low and suck air into the system. It sounds simple enough, but I have seen people have to start completely over because they were in a hurry and didn't remember to refill the reservoir.
There should be a distinct difference in color between the old fluid and the new fluid. Once, you see only fresh fluid emerging from the bleeder screw the system has been completely flushed. As far as getting all of the air bubbles out, gently tap on all of the fittings in your brake lines to free all of the air bubbles that might have gotten stuck there. Then make sure that the master cylinder reservoir is topped off with enough fluid, install the caps, replace the rubber covers over the bleeder screws, and you are finished.
Now, before you run out and test your brakes on the road it is a good idea to pump the brake levers to make sure that there is sufficient pressure in the system. Also, roll the motorcycle slowly and test the front and rear brakes before you hit the road. Double check to make sure that the pads are securely held in place and the calipers have been torqued correctly to there mounting locations. New pads usually require a certain amount of break-in for them to function correctly. Check with the pad manufacturer for proper break-in times and procedures. If you upgraded pad materials from your previous type, keep in mind that there is probably going to be a noticeable improvement in stopping power and initial bite. Take time to get used to your new setup so you don't hurt yourself or your precious motorcycle.
http://www.motorcycle.com/mo/mcnuts/braketech.motml
March 3, 2006, 07:03 AM
I just changed my rear pads last night. It's a good idea to never hit the brake lever when the pads are out. Tape it or block it before you start the work.
2 wheels for life
Deep's Avatar
February 12, 2011, 10:28 AM
Vacuum brake bleeder or speed bleeder??
and where to get the stuff?
Adrenaline Addict
Go slow to go fast...
RRonin's Avatar
February 12, 2011, 01:28 PM
Sears sells vacuum brake bleeders. After you figure out how they work they are awesome!
Tony
1-12-2010
  Send a message via AIM to Send a message via AIM to RRonin
Don't ask me,I'm Canadian
C2H5OH's Avatar
February 12, 2011, 03:08 PM
Speed Bleeder all day!
I'm a llama again!
Slider's Avatar
February 12, 2011, 03:40 PM
Also not sure if it was said. Try and use gloves when handling the pads and try also not to touch the disks with you bare hands. If you do clean them.
RADAR Magnet's Avatar
September 7, 2013, 06:49 AM
I'm going to be doing some of this stuff today (replacing mc, calipers, pads, rotors). What's wrong with allowing your skin to come in contact with the pads?
05 CBR600RR
Cager
JarvisB's Avatar
September 7, 2013, 07:30 AM
I think he want to avoid any oil residue getting on the discs or pads. I wouldnt worry too much about it, but I suppose he is right in theory.
-J. Beaver
--bike-less for now
September 7, 2013, 07:56 AM
Thanks. One follow up - is a 2 year old bottle of brake fluid still good if it hasn't been opened (motul 600)?
05 CBR600RR
September 7, 2013, 08:13 AM
Sealed bottle? Hell yeah. I'd use it.
turn or crash....
djkouza's Avatar
September 7, 2013, 08:21 AM
Yeah but also depends on how it was stored. ....Actually It's almost definitely better than what's in your bike so yeah go for it. I mean if this is two years old then my guess is the fluid in the bike is older and also it's been through allot more.
- djkouza
Bikes: I might own one...
djkouza - XBOX
September 7, 2013, 08:28 AM
Yep, still sealed. Looks like I can save a few bucks.
05 CBR600RR
September 7, 2013, 08:40 AM
Originally Posted by djkouza View Post
...depends on how it was stored.
Not really. If it still has the factory seal intact under the lid and there aren't any holes poked into the bottle he's good to go. There is no expiration on brake fluid that has not been subjected to dirt or water absorption.
September 7, 2013, 09:18 AM
Just an FYI.
Vaccuum brake bleeders - worth their weight in gold when starting from scratch.
As for what to do if you don't have one, crack bleeding works fine.
I just tore apart both front and back calipers, full teardown, cleaning, and replacing the caliper seals. My rear brake had been failing and having issues. It's a Brembo. So I went the route of buying a seals kit, removing it from the bike, draining it, pulling the pistons & seals and dropping it in the ultrasonic cleaner. Then I just installed new seals, slid the pistons back in, and refilled the system with fresh brake fluid.
The hardest part? refilling it with fluid. I dragged out my brake vaccuum. Voila! In about 15 minutes I had brakes that were perfect.
The hydraulic braking system really is the easiest thing in the world once you take a look at it. I did the brake MC piston refresh as well. That was a little more complicated, but not much. Take your time, keep things clean.
As for not handling the brake pads with your hands? Really? If it were that sensitive then your brakes would fail all the time. If you are really worried, buy a can of brake cleaner and hose the pads before mounting on the rotor.
I'm around today at home prepping for an enduro tomorrow. If you need help I'm in Ashburn.
Mud
September 7, 2013, 09:29 AM
Originally Posted by MudDawg View Post
Just an FYI.
Mud
Could you come out to Woodstock and show me how to change dirtbike tires?
