» Online Users: 561
6 members and 555 guests
CCS762ZX6, davidcycle, Nobrains, Sal_the_man, Scot, Slider
HOW-TO: Ride in a Group
BE ENCOURAGED!
GUZZ's Avatar
HOW-TO: Ride in a Group - May 24, 2006, 10:05 PM
With the riding season well under way and all the upcoming group rides being planned, I thought it might be a good idea for the new, as well as the more seasoned riders to review the basics of a group ride. I found this info on another site:
Group Riding
There are more and more people getting together as groups not only for impromptu short excursions but also for organized rides. A group ride could be defined as any group of two or more motorcycles riding together. There are many specifics concerning group riding, including, instructions before the ride so everyone understands the hand signals, the route, how long between rest stops and a myriad of other necessary instructions. This article is not going to go into specifics, but rather into the general guidelines of group riding so as to have a safe ride; but not be so overwhelmed with things to remember as to take away from the enjoyment of the ride.
Riding Formation
A Group Ride is normally composed of a Ride Leader and a Sweep or Drag Rider (bringing up the rear). For organized rides they usually have Radio or CB communication and knowledge of the route including not only the final destination, but also the stops along the route. If more riders in the group have radios, then casual chatter during the ride should be kept to a minimum by the riders of the group so that the Lead and the Sweep Riders can be in instant communication whenever needed. Motorcyclists normally will monitor Channel 1, but this can be easily changed if a new channel is agreed upon before the ride starts, or even during the ride, if necessary. If communication between other riders in the group is desired; then they should go to another channel.
Normal riding as a group is done in a staggered formation. This is, basically, dividing a lane in half with each rider occupying his/her own half of the lane. It is each rider's responsibility to ride in the half of the lane as dictated to by the next rider in front. If the rider in front needs to change lane halves to maintain the stagger, then it is the following rider's responsibility to change lane position on down the line to accommodate this change. The Lead Rider usually starts the stagger in the left half of the lane position. While in staggered group riding, the normal stagger distance is 1 -> 2 seconds, and no more than a 3 second gap, in order to maintain a tight formation and not allow traffic to interrupt and break up the formation. This means that each rider will be 2 -> 3 seconds behind the rider directly in front and using the same half of the lane. When coming to a stop, the group generally forms up two abreast / side by side. When the group starts off, the rider on the left starts first.
When riding in curves, the stagger is no longer warranted and a single file type of formation is normal. These changes in lane position should be dictated by the lead Rider. Holding two fingers straight up in the air (either the index and little fingers, or the first two fingers) indicates a staggered formation, while the index finger pointing straight up in the air is a direction for single file riding.
Single file riding allows the riders more freedom to negotiate the curves and to dodge obstacles while having the freedom to use the whole lane. In single formation the normal distance between riders is increased to 3 -> 5 seconds. For safety, the single file formation should not be elongated to such a distance that the rider in front cannot be seen. There are two reasons for this:
1. It is much easier to negotiate around corners by using the next rider's position to "see" further around blind curves
2. The rider can see and pass back hand signals indicating obstacles or other information ahead.
If any rider feels that the group pace is too fast for comfort, then he/she should motion the following bikes to pass until the only one left following is the Sweep/Drag Rider. Then ride at your own pace until the next stop; when you should inform the Lead Rider that you are uncomfortable with the pace. It will then be up to the Lead Rider to either separate the ride into two groups, or go at a slower pace so that all members of the group feel secure. Group riding should not be, and is never, a race!
If a rider in the formation needs to pull out for any reason, the group will close up the gap and reorganize the stagger. Please do not pull off, also, unless you need to do so. The Sweep/Drag Rider of the group will aid the rider who has pulled over. He will also communicate (via radio) with the Ride Leader so as to apprise him of the situation. The next (last) rider then becomes the Sweep/Drag rider until the Sweep/Drag rider returns to the group.
When turning onto another road, if the next rider back cannot be seen, either due to having traffic in-between, or a large enough gap in the group for any reason; the last rider in the line must wait at the turn for the next rider to show up before leaving the turn so as to signal that the route has taken a turn. This will keep the group together on the same route even though there may be unforeseen gaps in the formation.
Passage of Information through Signals
During the ride, the Ride Leader will make various blinker light, hand, and leg signals. These signals indicate lane changes or turns, obstacles, increasing/decreasing speed, or whether to form a stagger formation or a single line. These hand signals need to be passed back through the group from the front rider to the next rider in line. That way each rider only needs to be cognizant of signals from the rider directly in front of him/her rather than everyone trying to keep an eye on the Ride Leader.
Blinker lights should always be used to not only allow everyone to see the upcoming change, but to feed back acknowledgment. In a group ride, whether it be the Ride Leader or in the middle of the pack, the bike in front needs to see the blinker light of the following rider before turning in front of the following rider/bike (such as a right hand turn when the bike in the left stagger crosses over in the right stagger lane). This prevents the bike in front from crashing into the (surprised/unprepared) following bike/rider when making the turn. Assuming that the following bike sees your blinker light. Sometimes riders don't notice blinker lights right away, so they should be turned on well before the turn. That way everybody in the group becomes aware that a turn is coming up.
If an obstacle is spotted in the road, it should immediately be signaled to the riders in back for safety. Sometimes, when the obstacle is spotted in a blind curve, and one doesn't want to take one's hand off the handlebars, the signal is often done with an outstretched leg (indicating which side of the lane the obstacle is located). This can be very useful when you don't want to take your hand off the throttle and the obstacle is on the right side of a blind curve. Some typical obstacles which should be signaled as to where they may lie in the lane are: sand/dirt/gravel/rocks, pot holes, dead animals, road dragons, (pieces of truck tire treads), vehicular debris, range cattle, tar snakes (road tar repairs), furniture, etc. These obstacle signals should always be passed to the rear as soon as possible so as to give those riders the best opportunity to dodge them. Don't forget that the riders towards the rear in a group ride will not be able to see as much of the whole road surface as those in front due to the visual blockage of the front riders. Other hand signals include speed changes, directions for coming alongside or passing, need for food or rest stop, and other miscellaneous things like telling another rider that his blinker light is on unnecessarily.
Riding Strategies
There are certain tips which, when incorporated into one's riding, will make the ride safer as well as enjoyable. The following are some generalities of how to ride in rural areas. Range cattle have the right of way. Riders should slow way down for cattle found alongside, or in, the roadway. Some of these, especially the calves, become skittish and very often bolt directly in front of the bike, so have your brake covered in case you need to come to a complete immediate stop.
Some years seem to have a bumper crop of locusts which like to crawl out on the roadway to sun themselves. Although, in places, the road might appear to be covered with them; don't worry about losing traction because of them. You will not hydroplane (skid) over them unless you are in a full fledged migration, or swarm.
When there are an abnormal number of locusts on the road, there also seems to be an overabundance of locust eaters, or chipmunks and ground squirrels. These can sometimes be seen down the road in the dozens in certain areas. Even though no one wants to hit one of these cute little critters; do not attempt to dodge or brake for them as this will actually increase the odds that you will hit them. They will dodge or stop at just the last moment, and if you attempt to swerve or brake for them; you will be more likely to lose control if you do hit one. On those occasions where you are worried about hitting one of them; just get a good grip on the handlebars and ride your line. At worst, even when leaned over in a curve, you will only feel a slight bump if you happen run over one.
Sand/gravel is sometimes found in curves from cars and trailers running a wheel off the roadway and "splashing" up some of the sand/gravel from the side of the road. Sometimes in the springtime there are also some "dirty" sections of the roads in the higher elevations due to snow melt runoff. When encountering a dirty roadway, the inside tire track of the lane (closest to the centerline) is almost always the cleanest part of the road and should be taken in a single file formation.
Cattle Guards while in curves are sometimes also encountered. These can be slippery, especially to motorcycle tires with their small contact patches. When wet, either with water or oil, they are extremely hazardous and should always be taken in a straight line while straight up on the motorcycle (no lean angle). This can be accomplished by doing the curve in two stages. The beginning of the turn before the cattle guard, then straight up over the guard, and finish the turn after going over it. This is known as a "double apex" for those who may not already know the technical terminology.
Conclusion
Group Riding can be a lot of fun if all the members are comfortable within the group. If one or more members of the group are not comfortable; then this should be discussed at the next stop so as to accommodate or correct the cause of the problem. It's very easy to take each problem and, with a little tact, teach whom ever might not have a sufficient understanding of these simple rules. We all can then enjoy the fine sport of Motorcycling.
Happy & Safe Riding Everybody!
Que se jodan!!
Whisper's Avatar
May 24, 2006, 10:26 PM
Thank you, sir! A good firm kick in the mental ass.
Whisper
"Speak quietly and carry a big stick."
2014 BMW S1000RR
2006 GSXR 1000 - Street (Sold)
2005 GSXR 1000 - Track (Sold - I hate you, Paul)
2010 YZ250F -Motocross in Mexico (I still hate Yamahas)
Men are qualified for civil liberties in exact proportion to their disposition to put moral chains upon their appetites: in proportion as their love of justice is above their rapacity...Society cannot exist, unless a controlling power upon will and appetite be placed somewhere; and the less of it there is within, the more there must be without. It is ordained in the eternal constitution of things, that men of intemperate minds cannot be free. Their passions forge their fetters. ~Edmund Burke, Political Theorist and Philosopher
Some of us are lions, but even lions can be crushed under the elephant of bad management.
  Send a message via AIM to Send a message via AIM to Whisper
unapologetic
Hollywood's Avatar
May 24, 2006, 10:30 PM
Good post, Guzz.
And for goodness sakes', all of you look out for the swarming hordes of locusts and grazing free range cattle!
"ride on #47, ride on"
Spectroscopist/adventurer
fireclown's Avatar
Thumbs up May 25, 2006, 07:23 AM
Originally Posted by Hollywood
Good post, Guzz.
And deer, for those of us out here in the stix. I thought I was going to buy it that way a few weeks ago. Unlike Hollywoods cows, they will move, but they tend to bounce in a random direction, and it could be at you <<shudder>>.
Thanks for the refresher, Guzz. I just finished my first group ride this past sunday, in Frederick. Had a great time, learned more about the sportbike in those 3 hours than in the rest of the time on the bike combined, and I will be back for more.
whats in your drink?
DRAGULA's Avatar
May 25, 2006, 08:23 AM
Brilliant. Thank you sir.
Tell 'em Large Marge sent ya!
X
1 of DA PAK FOUNDERS!!
May 25, 2006, 09:03 AM
thank you sir!!!
R1 , 2001
Gixxer 2005
  Send a message via AIM to Send a message via Yahoo to Chico Send a message via AIM to Chico
Squid Rider 4 Life!!
ArRrR6's Avatar
May 25, 2006, 09:15 AM
you da man Guzz
  Send a message via AIM to Send a message via AIM to ArRrR6
May 25, 2006, 09:28 AM
Awesome post!
Site Owner
ClemsonJeeper's Avatar
May 25, 2006, 09:34 AM
Moved and renamed into the HOW-TO section.
Great post Craig!
Katie #135.
B: that sounds odd
Topdog's Avatar
May 25, 2006, 09:38 AM
thx
ThrustinJZX6's Avatar
May 25, 2006, 11:22 AM
I would like to add: Don't blow by the leader doing 100mph on a normal paced group ride on a Honda v-twin sportbike. It's scares the bejezzus out of him/her.
True story.
'00 Kawasaki Ninja ZX6-R
'03 Honda XR100R
Xbox: ThrustinJ
God Made Me Wrong
Bexxx's Avatar
May 25, 2006, 12:18 PM
Great post, Guzz!
"Always question those who are certain of what they are saying." - Elie Wiesel
When the time comes to leave, just walk away quietly and don't make any fuss.
Originally Posted by tfinch
Why does SnoopDogg carry an umbrella?...Fo' drizzle.
Originally Posted by Whisper
Stop putting shit in my papusa!
When people I don't even know don't like me, I figure I'm doing something right.
  Send a message via AIM to Send a message via Yahoo to Bexxx Send a message via AIM to Bexxx
On the short bus
JJester's Avatar
June 5, 2006, 07:42 PM
Very Nice post.
Your dirty Uncle
pokey's Avatar
June 5, 2006, 09:32 PM
True story.
And then some freak from the group you just raped will come out of nowhere and make you wet your pants right when you're slowin back down.
Vindictive little biatches.
Also true...
yeaaahh that's right, seeee.
Thanks GUZZ
" Fire Fire Fire"
David " what happens if you look at them?"
Pokey " I don't know, I've always avoided eye contact..."
David " Hello, my name is David and I turned to stone."
On the short bus
JJester's Avatar
June 10, 2006, 07:56 PM
Bump
