» Online Users: 566
3 members and 563 guests
BlackHatch, GRN96WS6, onel0wcubn
New steel brake lines, brake pads and steering damper (Scott stuff)
Flying tiger
rwanda91's Avatar
New steel brake lines, brake pads and steering damper (Scott stuff) - March 9, 2013, 11:48 AM
It's for the 06 R6.
If you have any pointers I take!
One week to do the homework and I start next week end.
Also, what would you automatically check / replace when purchasing a used bike?
09 Yamaha Fazer 600 "Black Mamba" *** Totaled ***
07 Yamaha TT-R 230 ***Sold***
03 Honda CRF 150 F ***Sold***
06 Yamaha R6 (50th Anniversary Edition) ***Stolen***
turn or crash....
djkouza's Avatar
March 9, 2013, 11:53 AM
Chang oil at a minimum. Honestly you should check everything brakes, tired, plugs...
Sent from Forum Runner
- djkouza
Bikes: I might own one...
djkouza - XBOX
GiixerFiend7's Avatar
March 9, 2013, 12:31 PM
Brake
change.
March 9, 2013, 12:35 PM
Ok so you should change the oil and filter, check the air filter, check the brake pads, check chain and sprockets for excessive wear, pull a spark plug or two out to check, oh and flush the coolant and flush the brake fluid.
change.
Flying tiger
rwanda91's Avatar
March 9, 2013, 01:29 PM
Many thanks. I already have the brake pads and lines from previous bike and they should fit.
Chasing the dragon
okayh's Avatar
March 9, 2013, 09:03 PM
Originally Posted by GiixerFiend7 View Post
Brake
+100000 (pet peeve)
If you don't know the seller and trust what they are telling you (99% of folks) then:
- Change all fluids
- Check the air filter, change if needed
- Check the brake pads
- Inspect rubber hoses
- Inspect under the tank and under the seat for hack jobs
- Check the chain and sprocket. Clean & lube or replace as needed
- Check and tighten all the bolts you can get to, stuff on the forks, AXLES, fairings....
- Go for a ride and blow the dust off the pistons
Download your bikes service manual as well.
More gas, less brake
GDMFSOB
The Evil Twin's Avatar
March 10, 2013, 08:02 AM
Originally Posted by okayh View Post
+100000 (pet peeve)
- Check and tighten all the bolts you can get to, stuff on the forks, axels, fairings....
Axles. Pet peeve of mine
Yo OP, you leftout a bunch of helpful details (did it come from street/ track, have records, miles, etc).
Oil, filter, brake fluid- change
Coolant- flush the system and check the hoses for cracking or brittle feel.
Air filter- clean or replace
Chain- clean and lube, adjust
If the bike came from the street, and is between 10000- 15000 miles then fuck checking the plugs. 15000- 20000 miles; then might be a good idea. However, if you are going to go that deep then you may as well replace them. If they are the standard copper core then they are cheap. If they are iridium then leave them. Iridium plugs should not be cleaned or gapped according to Bosch and NGK. Their duty cycle is about 4 times that of copper core. In a bike that is about 30,000 miles. A car up to 100,000.
Anyhoo, holla if you have any questions.
#132 EX
2015 MARRC Crash & Burn Award
Flying tiger
rwanda91's Avatar
March 10, 2013, 09:26 AM
Thank you!
The bike has 11k mi and comes from a dealership.
Yesterday I bought all the filters and fluids except the coolant that I forgot.
The bike looks very clean from outside at least.
Flying tiger
rwanda91's Avatar
March 10, 2013, 09:47 AM
Also, do you have a bleeder to recommend?
Track Day addict
2blueyam's Avatar
March 10, 2013, 12:51 PM
I would think that by check the plugs, he meant check them to see if the bike is fueling ok, not check to see if they need replacement. If it has a stock exhaust and no tuning kit on it, that step would not be necessary. Full exhaust other no tune, then forget checking the plugs as well and get it tuned. Depending on the bike you may be able to get to one of the plugs to check it fairly easily, others not so much.
Dale - 2004 SV 650 track, 2003 R1 track, 2007 Tuono
GDMFSOB
March 10, 2013, 03:36 PM
Thank you!
For speed bleeding- Mi-T-Vac, or equivalent. You can get a generic one from Harbor Freight that I have used a shit ton. Still, after you get get solid fluid out ,I would go with the ol pump, pump, squeeze a few times at the end. I'm just old school....and I like pump, pump, squeeze
At 11k (unless you TRUST the dealer) I would just replace the plugs. If the service department says they were done, and you believe it, then you are cool. I think they are due at 8k.
True dat!
#132 EX
March 10, 2013, 06:39 PM
Yes I was referring to fueling.
change.
On vacation
RileysDad's Avatar
March 10, 2013, 09:26 PM
FWIW, I've bled plenty of brakes and I've never used a formal bleeder. I have a trusty plastic olive container (mediterranean I think, I remember that they were delicious) with the lid drilled to fit a 1/4" hose. I then run the hose to the caliper over the closed end of an 8mm wrench for opening the bleeder, which locks it in place. Not the most scientific approach but definitely cheaper than a formal bleeder.
She asked my opinion
turn or crash....
djkouza's Avatar
March 10, 2013, 09:52 PM
This, although not the easiest to do with just one person.. so if you have the coin get a bleeder probably worth the $40 or whatever they cost. Also I put speed Bleeders on my 750, highly recommend those too!
- djkouza
djkouza - XBOX
Flying tiger
rwanda91's Avatar
March 10, 2013, 11:11 PM
Thank you!
Search results for: 'bleeder'
Any preference?
