» Online Users: 542
4 members and 538 guests
2blueyam, davidcycle, GRN96WS6, onel0wcubn
Problem mounting tire
S1000RR's Avatar
Problem mounting tire - February 12, 2011, 03:48 PM
I am trying to mount a tire on a 17' rim. The tire is the correct size for the rim but when I go to inflate it there is a spot where the bead does not move out and connect with the rim. So there is a gap on both sides of the tire. Any suggestions?
February 12, 2011, 03:56 PM
make sure no spurs are there.
lubricate it.
2 wheels for life
Deep's Avatar
February 12, 2011, 04:33 PM
You have enough air pressure right? it does not pop with those weak portable compressors
Adrenaline Addict
February 12, 2011, 04:37 PM
Lube, as already mentioned. Make sure the tire is nice and warm, it will make it much more flexible.
You can use a cinch strap around the entire circumfrence of the tire to try to get it to bulge out to meet the rim so you can get a seal, but long before I resort to breaking out a cinch strap I'll reach for the can of ether and simply blow the tire onto the rim. It's not something I recomend, but it works and makes the job go quick. Do a youtube search on mounting tire with ether and you'll see what I mean. Note: A little goes along way, some of the vids show folks using way too much.
February 12, 2011, 06:22 PM
Did you remove the valve core?
Playing in the dirt
jar944's Avatar
February 12, 2011, 07:15 PM
Windex the on the tire and rim.
What PSI are you stopping at?
KTMs and Yamahas
Space's Avatar
February 13, 2011, 09:18 AM
This is the only post that needs to be here.
Space's Avatar
February 13, 2011, 09:20 AM
Not true. Its about volume and there is only so much a 1/4" hose can deliver regardless of the compressor.
Space's Avatar
February 13, 2011, 09:21 AM
not necessary
Space's Avatar
February 13, 2011, 09:22 AM
40 psi is the generally recommended max psi to seat the bead.
February 13, 2011, 09:40 AM
Originally Posted by Space View Post
not necessary
But a simple solution if he hasn't.
February 13, 2011, 10:16 AM
Edited: I'll wait until the next group ride.
Space's Avatar
February 13, 2011, 10:42 AM
If he has a an inflator that doesn't require the valve. The improvement on flow is minimal. The biggest problem is losing more air than is being supplied. Generally speaking. I have done thousands of tire changes with professional equip. and diy stuff. Most of the time if the bead won't seat a strap is the easiest diy solution.
The rim clamp we used gave a high volume blast of air to help seat bead.
June 29, 2011, 10:23 PM
furniture polish from the dollar store!get the spray on so theres no mess.it doesnt hurt the rubber and works great.its fast,easy and cheap! hope this helps
Give me the Ban Button!
Nubbs's Avatar
June 30, 2011, 07:19 AM
So did he get it seated? The sinch strap is by far the safest route to go.
