» Online Users: 556
5 members and 551 guests
davidcycle, GRN96WS6, Scot, Slider, tonetone
Need some machining
KirkRoy's Avatar
Need some machining - August 15, 2013, 08:13 AM
I'd like to get stainless steel copies made of the aluminum chain adjuster blocks for my KX. They are very simple, basically like the pic below but without the recessed section around the axle holes. Before I hit up a local machine shop can anyone here help me out? I could probably make sturdier ones myself out of some really hard wood (lignum vitae) but probably should stick to metal.
August 15, 2013, 08:23 AM
I would like to help but I am super busy right now. Also you do know that using stainless will cause corrosion on the swing arm due to dissimilar metals. I have done this for others and without proper care the block can cause the swingarm to get ugly.
Why do you want stainless?
Playing in the dirt
jar944's Avatar
August 15, 2013, 08:58 AM
I'm with dodge on this, Al would be a better choice. Is there something wrong with the ones you have?
KTMs and Yamahas
KirkRoy's Avatar
August 15, 2013, 09:16 AM
I have 3 sets: 1 chewed up set that came on the bike; 1 chewed up set that came with a replacement axle I bought off ebay (original axle was messed up where it mated with the bearings); and a new set I just bought, now chewed up. I thought I was being careful when I put the wheel on last time, I cleaned up the axle, checked it over good, greased it, etc. When I went to pull it off I turned the nut and it spun easily enough. Then I realized the whole axle was spinning. So, now I chewed one up myself.
There's a slight gap between the axle flange and the block. Maybe if the flange fit more tightly against the block it would keep the axle from spinning. Or maybe if the block mated with the flange on both sides, like this one:
turn or crash....
djkouza's Avatar
August 15, 2013, 09:19 AM
Sounds like OP isn't happy with the quality of the AL ones, but since I don't know shit, I'll just agree with Dodge because what he said makes sense to me.
EDIT: well OP beat me to it..
- djkouza
Bikes: I might own one...
djkouza - XBOX
Playing in the dirt
jar944's Avatar
August 15, 2013, 02:43 PM
yep, 2 flanges and they should be a tighter fit.
stripped axle block - Kawasaki 2-Stroke - ThumperTalk
KTMs and Yamahas
↓ dn ʎɐʍ sıɥʇ ↓
Dark's Avatar
August 15, 2013, 02:49 PM
Sounds like all you need to to have a tighter tolerance on your next set of blocks, which means you should be able to stick with aluminum.
KirkRoy's Avatar
August 15, 2013, 03:05 PM
Yeah, if it was a tighter fit AL would be fine, particularly if it was held on 2 sides. Shoot, I could probably make one out of AL using my woodworking stuff (carbide). I understand that makes a LOT of chips though.
KirkRoy's Avatar
August 30, 2013, 01:20 PM
Is there any place I can buy some AL locally?
Quasimoto's Avatar
August 30, 2013, 02:27 PM
Why don't you just buy new ones?
KX250 REAR WHEEL AXLE BLOCKS KAWASAKI KX 250 2003-2007 KX CHAIN ADJUSTER BLOCKS on eBay!
Gots_a_sol's Avatar
August 30, 2013, 02:52 PM
There is an ebay seller in Glen Burnie (I think) that sells all different kinds of AL up to like 6" thick.
-Joe
17 Beta 250RR/RE
09 Husky WR177
Playing in the dirt
jar944's Avatar
August 30, 2013, 03:12 PM
Cheaper to ship it in.
Try speedy metals or metals depot
KTMs and Yamahas
KirkRoy's Avatar
August 30, 2013, 04:51 PM
Originally Posted by Quasimoto View Post
Outside of oem you can't find new ones. The one you've linked to would not fit.
I'll check out those sources for raw AL. Thanks!
250 cc's of awesomeness
MXRider's Avatar
August 30, 2013, 05:53 PM
Check out the Ride Engineering blocks, they are much better than factory.
http://www.ride-engineering.com/searchproducts.php
KirkRoy's Avatar
August 30, 2013, 06:02 PM
Yeah, unfortunately everything that's out now is for the 03+ bikes with the 25mm axles. The earlier bikes all the way back to at least the 94 (mine is a 00) were 20mm. Pro Circuit still has them listed on their website but as "back ordered". I sent them an email asking if they're really back ordered or if they'll ever produce them again. I bet not. It is a simple thing to make if you're not trying to make them all pretty. I could make a set out of wood in 10 minutes.
