» Online Users: 610
2 members and 608 guests
Nobrains, tonetone
Go Back   DCSportbikes.net > Brand Specific > Vintage
Electrical Issues with a 78 CB 400 T
Electrical Issues with a 78 CB 400 T - August 15, 2011, 11:19 AM
I am cafe-ing the aforementioned bike and have run into a bit of a problem. And since many of you seem to know your way around older bikes, figured I throw this issue out.
I am re-connecting the wiring harness to the instrument cluster/headlight/horn. I have removed the turn signals, so the headlight bucket is nice and clean looking. My issue is I have gotten the instrument cluster lights all working (except the turn signal indicator, but that's understandable since there are no signals) but the headlight doesn't work. When I plug the headlight in, the high beam indicator won't turn off regardless of whether the high beam toggle is on or not. When I unplug the headlight, the high beam indicator works properly.
Any thoughts?
Thanks.
Don't believe the hype...
w0bbles's Avatar
August 15, 2011, 10:49 PM
Possibly switched the low beam/high beam wires?
'11 Speedy
'72 CB450
BrianRacerboy's Avatar
August 15, 2011, 11:58 PM
Google is your friend. I too had some electrical drama from my 74 CB550, but a quick search on Google and I found a wiring diagram. Just trace your wires and see where you got it wrong.
August 16, 2011, 08:26 AM
Doc, I didn't remove or disconnect any of the hard connections, just plugged everything back in.
Brian, thanks, but I have the diagram from the manual. I have run the lines all the way back to the fuses..
Back to the experimentation.
August 16, 2011, 09:50 AM
Did you try checking to make sure the headlight is getting power to it? It could be a bad headlight, my low beam just went out last week. Also, check all your grounds. These old bike depend on good grounds otherwise nothing will work.
