» Online Users: 528
2 members and 526 guests
davidcycle, tonetone
Go Back   DCSportbikes.net > Brand Specific > Vintage
JMR Customs Honda CB450 - 1982 CB 450 Honda Nighthawk
JMR Customs Honda CB450 - 1982 CB 450 Honda Nighthawk - January 10, 2013, 07:45 AM
YACBCR
JMR Customs Honda CB450 with a YZ front end
via pb:
PB:
“Hello, my name is Josh Mott. I’m 22 years old and owner of JMR Customs in Boise, Idaho. I’m a 3rd generation mechanic, racer, and bike builder. I’ve been racing for 10 years in many disciplines such as: flat track, arenacross, endurocross, and desert racing. Currently I’m in the National Hare & Hound series.
From a very early age I’ve helped my dad (Randy Mott) repair, service, and build custom motorcycles. Notable achievements include building a 1200 Sportster that ran an 11 second quarter mile and restoring a 1964 Greeves Challenger. I find a great deal of influence from custom styles: café, street trackers, bobbers, and basically any one-off custom motorcycle.”
“This 1982 CB 450 Honda Nighthawk was originally picked up to part out and sell on eBay. It was roached beyond belief. It had bent forks, a wiring harness that was stripped, and a missing fuel tank. Out of curiosity I thought I’d check the compression and spark to see if it had some sort of working order. It had 175 psi in both cylinders and had spark. I decided to clean the carbs and it fired right up.
I had an idea that I wanted to put a motocross front end, lowered down, on a café style build. I had a 2006 YZ250 Yamaha front end sitting at the shop waiting for a project at the time, it was perfect. I ended up lowering the forks 7 inches to get the right height. As I finished this portion of the build, I then had the idea to mount a mono shock. I used a 2005 TT-R 250 Yamaha shock because it fit really well in the small space I had to work with.”
“The fabrication work included many modifications. I cut the whole back half of the frame clean off to begin the custom portion. I had the older Champion flat track frames in mind where the frame was exposed right below the rear fender. I wanted the seat portion to sit within the frame.
The overall bike length looked shorter than I preferred so I cut the frame by the headset and raked it from the stock 28 degrees to a custom 34 degrees. I center mounted the fuel tank which involved cutting the top of the tank out. While I had the top of the tank out, I mounted a sleek, flush mount gas cap. Custom exhaust pipes were made to fit some after market Ducati mufflers I had, making the bike sound like an older Triumph. The wiring harness was custom made before I installed the motor. I have a key switch flush mounted on the right side of the frame and a start button on the left. There’s a little switch dashboard mounted under the coil and tank. There’s a high/low beam and a switch that turns on all the lights. I made a box that’s mounted underneath the motor - it holds the battery, starter solenoid, fuse box, and regulator rectifier.”
“I pulled the motor all the way down to replace the cam chain, rings and gaskets. While I was in there I cleaned up the intake and exhaust ports in the head. A Magura hydraulic clutch for a KX 450 was installed to replace the stock component. For a speedometer, I used a Trail Tech Vapor and made a mount that was clean to hide all the wires.
I’m very stoked on how this bike came together. It’s very unique in the sense that there’s really no name for what type of build it is. It has elements of café, motocross, and street tracker all in rolled into one. Anyway, thanks for looking.”
No more 1050 :(
drz1050's Avatar
January 10, 2013, 08:15 AM
Exhaust looks silly/ too big.. a 2-1 would be mo betta. Either that or smaller, more tucked in cans.
Raking out the front makes me sad.
Overall though - definitely not horrible. I likey!
↓ dn ʎɐʍ sıɥʇ ↓
Dark's Avatar
January 10, 2013, 08:23 AM
Needs a mesh rear
